Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 01-10-2017, 11:52   #1 (permalink)
pradyumnasahoo's Avatar
Member: 1267573
Thanks Meter: 106
Arrow i phone6 restored error..........
how to do a screenshot on a pc
Old 01-10-2017, 13:49   #2 (permalink)
Anamul.2014's Avatar
Member: 2145140
Sonork: 100.1650938
Thanks Meter: 90
if you get error 3004
Try this 5 Step bro_________________
Solution No.1: Restart your modem
Many users solved the issue within seconds, by simply restarting the modem. In most cases, the problem is the network connectivity, which is why this simple step this can fix the problem. Turn off your modem, and after 10-15 seconds, turn it on again. Connect your iPhone to your computer via USB cable, and try to update again.
Solution No.2: Restart your computer
Did you restarted your computer lately? If the answer is no, this solution may do the trick. Close iTunes, and restart. Turn your computer back on, and try to update or restore.
Solution No.3: Firewall
Firewall sometimes may be the problem. Allow iTunes in the Firewall options.
Solution No.4: Update iTunes to the latest version
All 5 ways to fix iPhone error 3004 are simple, including this one. Open the iTunes software and follow these steps:
If you are using Mac, from the menu, select iTunes, and Check for Updates;
If you are using Windows, from the menu choose Help, and then Check for Updates.
Solution No.5: Update or turn off your security software
Error 3004 may be connected with your security software. First, try to update it if you don’t have the latest version. If that does not help, simply turn it off, and restore or update your device.
Old 01-10-2017, 13:51   #3 (permalink)
Member: 2145140
Sonork: 100.1650938
Thanks Meter: 90
And Check Internet Connetion _______________
Old 01-10-2017, 17:57   #4 (permalink)
Member: 1267573
Thanks Meter: 106
no sir,in way this did not solve this............
Old 01-10-2017, 18:44   #5 (permalink)
Super Moderator
mihut's Avatar
Member: 824
Sonork: 100.1666666
Thanks Meter: 22,113
Error 3004
No internet connection during the firmware restore
__________________
Just Follow the Rules and Be Polite
Saying "thank you" can be hard. But it's so important.
Old 01-10-2017, 19:05   #6 (permalink)
Member: 1267573
Thanks Meter: 106
sir internet connection is ok.............
Page generated in 0.23223 seconds with 7 queries
