07-23-2015, 12:47 | #2 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Germany
Member: 2105007 Status: Offline Thanks Meter: 40 | using a non oem charging equipment, might have damaged the u2 ic on the iphone 6. This was a big issue in Iphone 5 series and since the iphone 6 is using almost the same u2 ic (16103) chip , it is possible we got the same issue. u2 needs to be replaced, if my assumtion is correct. |
08-01-2015, 08:52 | #4 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2437344 Status: Offline Thanks Meter: 0 | The source maybe your Charging cable or Charging cube. Pleae double check to make sure that they are original Apple products. Many charging USB cable and cube out there are low quality products and will damage your phone. USE original charger only. |
10-02-2015, 06:09 | #7 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | 95% just aftermarket charger. Try with 100% original charger. Don't listen to stupid people, aftermarket charger won't damage anything. 5V is 5V. I'm no expert but I'm selling/repairing phones for 15 years and have never seen a phone damaged by aftermarket charger. |
10-02-2015, 09:33 | #8 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: Indonesia
Member: 2281582 Status: Offline Thanks Meter: 26 | Quote:
Yaa.. Thats right.. But this case is board problem.. So if u not change u2 ic it wont charging even u buy original Charger.. :-).. So change u2 first then use original charger.. Sent from my iPhone using Tapatalk | |
11-19-2015, 12:19 | #10 (permalink) |
Member: 2281582 Status: Offline Thanks Meter: 26 | Anyone have solution of battre precentage not work .. For iPhone 6..change U2 still same .. Thanks Sent from my iPhone using Tapatalk |
The Following User Says Thank You to irzhan01 For This Useful Post: |
