04-11-2015, 05:28 | #136 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2367864 Status: Offline Sonork: Thomasen Thanks Meter: 0 | Tenorshare iPhone Data Recovery Mac It does seem though to be aimed at the backups made by iTunes when synching an Iphone with said program. If you don't use iTunes with your iPhone, then it's probably gonna be a professional recovery which will set you back a few quid. I don't usually post links to commercial software, but in this case, you don't have many avenues to explore, so it may help. |
04-11-2015, 10:07 | #137 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1917118 Status: Offline Thanks Meter: 0 | Solution for 53 Error! there is a fix for 53 error for iPhone 6 and iPhone 6 Plus which this error occurs. it doesn't work by changing the finger print TOUCH ID, the touch ID is not the issue or the Display. as it is the baseband chip which is troubling the phone. this is why apple stores are replacing the phone to one to one when it comes to error 53. its an major faulty in the phone. its starts first as partially working TOUCH ID where its works for some time and stops working and so on. I live in Sri Lanka. there is a shop in Dehiwela, Sri Lanka. where they has found this solution and will cost you like 7000LKR to replace the baseband chip. Contact Number : +94 771199991 |
04-11-2015, 17:38 | #139 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1044268 Status: Offline Thanks Meter: 0 | it is 100000000% issue of home button -- i also ha 3p of iphone6 an they all have lcd change with home button -- replace ur original home button and do flash you will get 100% OK |
04-13-2015, 17:07 | #141 (permalink) | |
Junior Member Join Date: Aug 2009
Member: 1096797 Status: Offline Sonork: 42525400 Thanks Meter: 0 | Error 53 iphon 6 Quote:
is related to touch id probalam pls not heat mathar boord | |
04-13-2015, 17:39 | #142 (permalink) | |
Insane Poster Join Date: May 2006
Member: 271255 Status: Offline Thanks Meter: 9 | Quote:
I've been saying it for along time in my own circles. There is something going on with this iPhone 6 Release, or a combination of things, they know about. Apple never gives away the farm, and on this phone they are; even if they are proving to recoup some of the loss through false problems. Something just isnt sitting right with this phone. Has any other repair shop had a preponderance of iPhone 6 customers calling/coming in with lines on the LCD(Or rainbow colors) despite there not being any cracks in the LCD, Digitizer, or frame; even under magnification? I've had a bunch in the last month or so, and I've had to send them all to Apple because of how inexpensively they are replacing the LCD assembly.....hmmmm... | |
04-15-2015, 08:50 | #144 (permalink) |
Member: 2367864 Status: Offline Sonork: Thomasen Thanks Meter: 0 | Recommend you can use Tenorshare iPhone Data Recovery Mac, which can easily recover all lost data from iPhone, no matter you lost iPhone data due to iOS 8.2/8.1/8/7.1 updates, jailbreak, factory reset and other reasons. |
04-26-2015, 10:39 | #150 (permalink) |
Insane Poster Join Date: Jul 2011 Location: rigga rd deira dubai uae
Member: 1623857 Status: Offline Sonork: madgenius Thanks Meter: 48 | check the history of your phone, coz error 53 is fault, when the original home button/finger sensor is replaced before by other finger sensor.. or any fault on its connection or flex.. |
