Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 05-24-2017, 13:48   #1 (permalink)
.::TEAM CCS::.'s Avatar
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Iphone 6 error 2009
How to fix Itunes error 2009 in iphone 6?
Changed USB cable(Original) not solved
Changed phones USB port (Not solved)
Old 05-24-2017, 14:06   #2 (permalink)
applebricks's Avatar
Member: 2609423
Sonork: 1660954:2007
Thanks Meter: 360
change battery and try
Old 05-24-2017, 15:07   #3 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Now Changed Even Battery but same ,
preparing phone for restore,then Error 2009
Old 05-25-2017, 19:50   #4 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Hasn't anyone faced this issue before ?
Old 05-26-2017, 13:32   #5 (permalink)
hardboy's Avatar
Member: 863309
Sonork: 4540726
Thanks Meter: 41
Give here code from log file iTunes
Old 05-26-2017, 15:40   #6 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Phone was working well , error appeared when trying to update
Is this the code?
2017-05-24 19:35:19.810|MDCrashReportTool.exe|628:4789776|Cra shReportCopierPrivate.m:_I_CrashReportCopierPrivat e__submitCrashReportFromPath_| ERROR: Error 4 while attempting to submit C:\Users\Celltrics\AppData\Roaming\Apple Computer\iTunes\iPhone Updater Logs\iPhoneUpdater 55.log.ips
Old 05-28-2017, 15:23   #7 (permalink)
Member: 2695850
Thanks Meter: 18
you need open this file and paste here results
Old 05-29-2017, 08:05   #8 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Please Help to solve . Error Code below.
2017-05-24 19:33:05.509 [5532:1710]: restore library built Sep 22 2016 at 15:35:17
2017-05-24 19:33:05.509 [5532:1710]: iTunes: iTunes 12.5.5.5
2017-05-24 19:33:05.509 [5532:1710]: iTunes: Software payload version: 14F89 (option key)
2017-05-24 19:33:05.509 [5532:1710]: iTunes: Using MobileRestore state machine
[14:04:56.0752] requested restore behavior: Erase
 [14:04:56.0752] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
 [14:04:56.0752] Automatically set FormatForAPFS => True and FormatForLwVM => False.
 [14:04:56.0752] Changing state from '(null)' to 'Restoring'
 [14:04:56.0767] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
 [14:04:56.0767] amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device
 [14:04:56.0767] no override trust object found
 [14:04:56.0767] requested restore behavior: Erase
 [14:04:56.0767] requested variant: Erase
 [14:04:56.0767] amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is True
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 00E29908 [72B4907C]>{length = 20, capacity = 20, bytes = 0x979a9d2a92321001437638a2a663548380fad6b5}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 00E29950 [72B4907C]>{length = 20, capacity = 20, bytes = 0xcd73a6df67f4823719512eb407f784fc2fffcf12}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 00E2A178 [72B4907C]>{length = 20, capacity = 20, bytes = 0xd29d3e82267b13e5c6166c0f4092df6957ce8361}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 00E28CF0 [72B4907C]>{length = 20, capacity = 20, bytes = 0x745ab40bbd3d41852beb27d0a37f3cd8ff45f452}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "OSRamdisk" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 00E29B00 [72B4907C]>{length = 20, capacity = 20, bytes = 0x5bb3f1ea71399411b5e59ccfb66c1f92fca7e198}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 00E29C20 [72B4907C]>{length = 20, capacity = 20, bytes = 0x8c1ebd71f6e1d6acee611f59ad9d7e005c9c523a}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 00E295A8 [72B4907C]>{length = 20, capacity = 20, bytes = 0xc1046e69c2e98fdb91ab227b8094984e41f16e8d}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ftap"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "rfta"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ftsp"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "rfts"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Diags" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "CFELoader" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "RBM" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PHLEET" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PERTOS" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PEHammer" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Alamo" not part of manifest, skipping
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "OS"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 00E29A70 [72B4907C]>{length = 20, capacity = 20, bytes = 0x695061228e4db1c978bd25c96217a7d2a42dda88}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 00E297A0 [72B4907C]>{length = 20, capacity = 20, bytes = 0xee24a931f9fad560ed3dc8f3841d08d251fd950e}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 00E29B48 [72B4907C]>{length = 20, capacity = 20, bytes = 0x651e2f83ac1887a4f27b17536750d710f7701970}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 00E295F0 [72B4907C]>{length = 20, capacity = 20, bytes = 0x9e480d2702fac4e58af8eb68876c6be77e8d6e0e}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 00E28900 [72B4907C]>{length = 20, capacity = 20, bytes = 0xf54d00678c16db5b7ed875191cc2951a7d512f5a}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "SEP" Digest = "<CFData 00E296C8 [72B4907C]>{length = 20, capacity = 20, bytes = 0x2a22f155eb9564456a8211563adcceed48f386cb}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 00E29A28 [72B4907C]>{length = 20, capacity = 20, bytes = 0x235a3e8f9f0af9496cc1b74547ec30239efdc82b}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreSEP" Digest = "<CFData 00E29998 [72B4907C]>{length = 20, capacity = 20, bytes = 0x24775602a57f3ff3485ee67d08e2112bff365695}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 00E28D80 [72B4907C]>{length = 20, capacity = 20, bytes = 0x42b71ff1f5a654e4807484012b76a8dacfe8d0f2}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 00E29C68 [72B4907C]>{length = 20, capacity = 20, bytes = 0x48a54eb36791096982d9870a6374ed9d0caee676}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 00E29B90 [72B4907C]>{length = 20, capacity = 20, bytes = 0x7bf0a4af3808212121fb8b0c49092a39eb2838c2}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 00E29758 [72B4907C]>{length = 20, capacity = 20, bytes = 0xd8d7854363275614e468aff26a1bf99ed1ef8d07}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 00E298C0 [72B4907C]>{length = 20, capacity = 20, bytes = 0x7844afd11fc704c2f52a860dbc5d2ffa5087ad50}"
 [14:04:57.0753] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 101EE730 [72B4907C]>{length = 20, capacity = 20, bytes = 0x9eb78d8b466126acf8dabb0c420024782088d5e6}
 [14:04:57.0753] amai: AMAuthInstallRequestSendSync: SSO function returned NULL and no SSO token was provided, SSO disabled.
 [14:04:57.0753] amai: tss_submit_job_with_retry: TSS Connection attempt 1 of 3.  (Will retry if TSS_ERR_SERVER_NOT_REACHABLE.)
 [14:04:58.0830] amai: tss_submit_job: HttpQueryInfo returned 200
 [14:04:58.0845] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0)
 [14:04:59.0143] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "OSRamdisk"
 [14:04:59.0190] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "ftap" does not require personalization; skipping it
 [14:04:59.0190] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "rfta" does not require personalization; skipping it
 [14:04:59.0190] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "ftsp" does not require personalization; skipping it
 [14:04:59.0190] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "rfts" does not require personalization; skipping it
 [14:04:59.0190] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags"
 [14:04:59.0190] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "CFELoader"
 [14:04:59.0190] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "RBM"
 [14:04:59.0190] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PHLEET"
 [14:04:59.0190] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PERTOS"
 [14:04:59.0190] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PEHammer"
 [14:04:59.0190] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Alamo"
 [14:04:59.0190] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "OS" does not require personalization; skipping it
 [14:04:59.0392] interface has 1 endpoints, file pipe = 1
[14:04:59.0392]
 [14:04:59.0408] iBoot build-version = iBoot-3406.60.10
 [14:04:59.0408] iBoot build-style = RELEASE
 [14:04:59.0408] unable to open device_map.txt: No such file or directory
 [14:04:59.0408] found device map entry for 0x00007000 0x00000006. boardConfig=n61ap platform=t7000
 [14:04:59.0408] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
 [14:04:59.0408] requested restore behavior: Erase
 [14:04:59.0408] AMDeviceIoControl: GetOverlappedResult failed
 [14:04:59.0408] AMDeviceIoControl: pipe stall
 [14:04:59.0408] USBControlTransfer: error 31, usbd status c0000004
 [14:04:59.0408] command device request for 'getenv radio-error' failed: 2008
 [14:04:59.0408] radio-error not set
 [14:04:59.0408] <Recovery Mode Device 055220D0>: production fused device
 [14:04:59.0424] <Recovery Mode Device 055220D0>: operation 4 progress -1
 [14:05:04.0425] AMDeviceIoControl: WaitForSingleObject failed
 [14:05:04.0425] AMDeviceIoControl: failed, error 997, usbd status c0000004
 [14:05:09.0941] AMDeviceIoControl: WaitForSingleObject failed
 [14:05:09.0941] AMDeviceIoControl: failed, error 997, usbd status c0000004
 [14:05:15.0457] AMDeviceIoControl: WaitForSingleObject failed
 [14:05:15.0457] AMDeviceIoControl: failed, error 997, usbd status c0000004
 [14:05:15.0965] USBControlTransfer: error 997, usbd status c0000004
 [14:05:15.0965] command device request for 'saveenv' failed: 2009
 [14:05:15.0965] AMRAuthInstallDeletePersonalizedBundle
 [14:05:16.0066] <Recovery Mode Device 055220D0>: Recovery mode failed (result = 2009)
 [14:05:16.0066] Restore completed, status:2009
[14:05:16.0066] Failure Description:
[14:05:16.0066] Depth:0 Code:2009 Error:Failed to restore device in recovery mode, libusbrestore error:2009
Old 06-04-2017, 03:03   #9 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 41
This could be a NAND chip problem, try to resolder the NAND chip or replace it
Old 06-04-2017, 12:44   #10 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Could not be done
*Changed USB PORT
*Changed Original USB cable,
*Updated Itunes,
*Tried changing U2,
*Reheated NAND.
*It gave Error 14, Error 9 & then itunes Waiting for iphone Error 4005.
But it could not be solved ! returned back to customer
Old 06-06-2018, 15:22   #11 (permalink)
Member: 228717
Thanks Meter: 28
Originally Posted by .::TEAM CCS::. View Post
*Changed USB PORT
*Updated Itunes,
*Tried changing U2,
*Reheated NAND.
i do you solve this problem ?
i have one with same problem
Old 06-06-2018, 15:28   #12 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Couldn’t solve this issue .
Sent from my iPhone using Tapatalk
Old 06-23-2018, 09:18   #13 (permalink)
Member: 2845893
Thanks Meter: 6
last time i encounter .
error 2009 is Nand IC problem .
Old 06-30-2018, 07:50   #14 (permalink)
SAEIDSANGAN's Avatar
Member: 1691551
Sonork: 100.1622582
Thanks Meter: 53
2009 problem is nand ic.
Old 07-30-2018, 07:22   #15 (permalink)
Member: 2833946
Thanks Meter: 108
Error 2009 is the NAND flash issue.
1. Check whether the NAND flash chip is pseudo soldered or damaged by measuring related resistance.
2. Replace the NAND flash chip.
The Following User Says Thank You to AmieeWhite For This Useful Post:
Page generated in 0.32345 seconds with 9 queries
