10-08-2015, 06:19 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: rajkot
Member: 1864687 Status: Offline Thanks Meter: 22 | iphone 6 error 4013 need help........ |
10-09-2015, 14:56 | #2 (permalink) |
Freak Poster Join Date: Aug 2005
Member: 172543 Status: Offline Thanks Meter: 126 | charge full battery and check the internet connection all thing will be fine i just test wright now after error 4013 the problem was slow internet connection,i restart the WiFi and job done regardes |
10-13-2015, 09:15 | #6 (permalink) | |
Freak Poster Join Date: Mar 2006
Member: 241855 Status: Offline Sonork: 1623913 Thanks Meter: 89 | Quote:
10-17-2015, 10:47 | #7 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2472221 Status: Offline Thanks Meter: 0 | Try these steps to restore your iOS device: 1. Install the latest version of iTunes. 2. Restart your computer. 3. Check for updates to your Mac or PC. If you restart your computer for an update, check for updates again after you restart. 4. Try to restore your device using another USB cable. 5. Try to restore your device on another computer. 6. Force your device to restart. If you continue to see error 4005, 4013, or 4014 when you try to restore your iPhone, iPad, or iPod touch, contact Apple. |
12-18-2015, 07:23 | #8 (permalink) |
Insane Poster Join Date: Jul 2015
Member: 2427042 Status: Offline Thanks Meter: 7 | use steps that are written bellow to solve the problem:- •Connect your iPhone to the computer. Fire up iTunes. •Backup your iPhone. •Now disconnect the iPhone, quit iTunes. •Put the iPhone in recovery mode. The short version goes like this: press and hold power and home buttons till the screen goes blank. •Open iTunes on PC. •Connect the iPhone. iTunes should indicate (through a dialog box) that an iPhone is detected in recovery mode. •Now go ahead and restore the device as new. This will erase everything but you will have the backup to restore from. |
12-19-2015, 10:48 | #10 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Home Sweet Home
Member: 1322701 Status: Offline Thanks Meter: 127 | Quote:
i think its RAM problem... did the phone fall? | |
