Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 10-08-2015, 06:19   #1 (permalink)
Member: 1864687
Thanks Meter: 20
iphone 6 error 4013 need help........
i have a iphone6 hang on apple logo some time recovery mode i restore 9.0.2 but error 4013 aftre waiting for iphone long time need help any expert plz help me i try another pc but same change dock but same change usb cable but same change battery but same.............arjantly help
Old 10-09-2015, 14:56   #2 (permalink)
Member: 172543
Thanks Meter: 118
charge full battery and check the internet connection
all thing will be fine
i just test wright now after error 4013
the problem was slow internet connection,i restart the WiFi and job done
regardes
Old 10-10-2015, 05:52   #3 (permalink)
Member: 1864687
Thanks Meter: 20
no brother this in not a solution net connection speed is 2mbps battery fully charge
Old 10-11-2015, 00:43   #4 (permalink)
Member: 2398349
Thanks Meter: 61
restore it on DFU mode and let itunes download the file and restore it itself
Old 10-11-2015, 00:43   #5 (permalink)
Member: 2398349
Thanks Meter: 61
dont use any other version on custom one!!
Old 10-13-2015, 09:15   #6 (permalink)
Member: 241855
Sonork: 1623913
Thanks Meter: 86
check the usb driver installs check task bar on driver installation and skip driver search online for either dfu or recovery
Old 10-17-2015, 10:47   #7 (permalink)
Member: 2472221
Try these steps to restore your iOS device:
1. Install the latest version of iTunes.
2. Restart your computer.
3. Check for updates to your Mac or PC. If you restart your computer for an update, check for updates again after you restart.
4. Try to restore your device using another USB cable.
5. Try to restore your device on another computer.
6. Force your device to restart.
If you continue to see error 4005, 4013, or 4014 when you try to restore your iPhone, iPad, or iPod touch, contact Apple.
Old 12-18-2015, 06:23   #8 (permalink)
Member: 2427042
Thanks Meter: 7
use steps that are written bellow to solve the problem:-
•Connect your iPhone to the computer. Fire up iTunes.
•Backup your iPhone.
•Now disconnect the iPhone, quit iTunes.
•Put the iPhone in recovery mode. The short version goes like this: press and hold power and home buttons till the screen goes blank.
•Open iTunes on PC.
•Connect the iPhone. iTunes should indicate (through a dialog box) that an iPhone is detected in recovery mode.
•Now go ahead and restore the device as new. This will erase everything but you will have the backup to restore from.
Old 12-19-2015, 08:47   #9 (permalink)
Member: 1031328
Thanks Meter: 22
bro its u2 ic damage change u2 ic then riestore the firmware
Old 12-19-2015, 09:48   #10 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 125
what was the problem of the phone before you restore?
i think its RAM problem...
did the phone fall?
Page generated in 0.30172 seconds with 7 queries
