Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 06-08-2015, 08:47   #1 (permalink)
Member: 1790819
iphone 6 error 47
anybody encountered this error 47 of iphone 6,after i replaced the lcd it becomes bluescreen and when i make sw its error 47..please help me regarding this problem...thanks a lot guys
Old 06-11-2015, 15:18   #2 (permalink)
Member: 1791741
Sonork: 100.1616400
Thanks Meter: 19
change charging base or battery your problem will solve
Old 06-22-2015, 11:16   #3 (permalink)
Member: 2391835
Thanks Meter: 2
Try to restore your iOS device two more times while connected with a cable, computer, and network you know are good. Also, confirm your security software and settings are allowing communication between your device and update servers.
Old 06-23-2015, 00:24   #4 (permalink)
Member: 2398349
Thanks Meter: 61
u misassembled the screws for the screen and u damaged the mother board.
search the forum for the solution!!
Old 06-25-2015, 07:10   #5 (permalink)
Member: 2415970
iphone 6 error 47
You must have to change charging base or battery your problem will solve or may be happen that you damaged your motherboard and that is happen sometimes with me . but i can solve this easily .
Regards,
Unmatchedsolutionpvtltd(unmatchedapp)
Old 07-04-2015, 15:38   #6 (permalink)
Member: 2295416
you need to check you have damage the prints under the screws.. it will be hard for you to repair if you are not expert in micro soldering.
Old 07-24-2015, 21:20   #7 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 477
Any real solution yet for iPhone 6 blue screen? I noticed it happens when the phone was dropped or the logicboard was bend. like a bad connection on the board that makes the startup check fail and shows the blue screen.
The Following User Says Thank You to HDccam For This Useful Post:
Old 07-25-2015, 15:20   #8 (permalink)
Member: 2433345
ithing problem in beasband ic check it
The Following User Says Thank You to safaasaleem For This Useful Post:
Page generated in 0.26991 seconds with 7 queries
