iphone 6 error 50 hi , today i recived an iphone 6 for lock user remove ,i get error 50 while restoring with itunes , |
As far I try to remove that error alwasy coming back. There is no way to remove this error, that is home button error. That cell waas in some shop to change lcd or glass and they change home button too, now mainboard doesn't see org code for home button. Have option if you have someone who work in apple service he can married that home button with that phone and everything work perfectly. |
Error 50 is not related to home button or touch ID. Infact it is related to baseband section. To get rid of this error. Analyze the motherboards Modem section for any short caps. Or try to reflow modem pmic or modem cpu... Maybe you even need to reball the modem cpu. Hope that helps. |
rehot bb pmu ic then try restore |
Remove screen, heat all phone to 80-100c, try to restore if it does then check what doesnt work. 60% its baseband, you should have no service |
[QUOTE=CDMA_RASHID;12454656]Error 50 is not related to home button or touch ID. Infact it is related to baseband section. To get rid of this error. Analyze the motherboards Modem section for any short caps. Or try to reflow modem pmic or modem cpu... Maybe you even need to reball the modem cpu. Hope that helps.[/QUOTE100% Tested By Replacing UPMIC search for Caps shorted to ground around UPMIC |
