Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 04-05-2017, 01:10   #1 (permalink)
Member: 2194348
Thanks Meter: 46
iphone 6 error 50
hi , today i recived an iphone 6 for lock user remove ,i get error 50 while restoring with itunes ,
Old 04-18-2017, 01:50   #2 (permalink)
Member: 1591139
As far I try to remove that error alwasy coming back.
There is no way to remove this error, that is home button error.
That cell waas in some shop to change lcd or glass and they change home button too, now mainboard doesn't see org code for home button.
Have option if you have someone who work in apple service he can married that home button with that phone and everything work perfectly.
Old 04-18-2017, 04:13   #3 (permalink)
Member: 2373358
Thanks Meter: 22
Try with 3u tools hope so it's will be ok
Old 04-18-2017, 06:57   #4 (permalink)
CDMA_RASHID's Avatar
Member: 821646
Thanks Meter: 481
Error 50 is not related to home button or touch ID. Infact it is related to baseband section.
To get rid of this error. Analyze the motherboards Modem section for any short caps. Or try to reflow modem pmic or modem cpu... Maybe you even need to reball the modem cpu.
Hope that helps.
Old 04-19-2017, 11:46   #5 (permalink)
Member: 574464
Thanks Meter: 33
rehot bb pmu ic then try restore
Old 04-24-2017, 00:16   #6 (permalink)
Member: 2628090
Thanks Meter: 5
Remove screen, heat all phone to 80-100c, try to restore if it does then check what doesnt work. 60% its baseband, you should have no service
Old 06-24-2018, 14:21   #7 (permalink)
Member: 2789841
Thanks Meter: 2
[QUOTE=CDMA_RASHID;12454656]Error 50 is not related to home button or touch ID. Infact it is related to baseband section.
Hope that helps.[/QUOTE100% Tested By Replacing UPMIC
search for Caps shorted to ground around UPMIC
The Following User Says Thank You to itechtanta For This Useful Post:
Page generated in 0.24838 seconds with 7 queries
