Iphone 6 error 9 I try to restore my iphone 6 always give me red screen and erreur 9 before its work fine plz i need you help |
Now it give me error 53 note the phone work fine before just sometime hang and restart any suggestion |
with error 53 check fingerprint sensor... |
Its work fine before Quote:
iphone 6 error 53 Hi Youssef, how did you solved first problem ( red screen and error 9) ? did you changed any part ? anyhow error 53 occurs once you change sensor ID/ Home button >>> so reinstall the old button May this help you |
I solved my problem by removing the metal shield for lcd screen it solve error 9 & 53 |
emoving the metal shield for lcd screen it solve error 9 same problem can anybody help in this after removing the metal shield for lcd screen error 9 same occur |
put it in DFU mode and restore again. Here's how. INSTRUCTIONS Step 1. Turn off iPhone Step 2. Hold down the power and home button. Step 3. When you see the Apple logo, release the power button but continue holding the home button down. Step 4. Open iTunes and wait for it to tell you that it’s in restore mode. Alternative Method: Step 1. Connect iPhone to USB then listen to the sound when it connect and disconnect. Step 2. Hold the home and power buttons until hear the disconnect sound then release power button. Step 3. Wait until you hear another sound then release home button. Also a video. [ame="http://www.youtube.com/watch?v=ROKCfzezGXw&feature=channel_page"]http://www.youtube.com/watch?v=ROKCfzezGXw&feature=channel_page[/ame] This way you can determine if it's software or hardware. Since you dropped it, might be broken. |
bro please write here correct solution error 53 for i phone 6 its home button problm clean the connector or change the home button cable its 50% chance & red screen is the audio ic problem rie hot audio ic or change it its 100% solution |
error 9 and restart bootloop and when u try to restore stuck on waiting ur iphone then its hdd problem reheat or change it ;) |
As per my knowledge error 53 (touch id senser/ home flex error) has been removed by apple. you just need to restore with the latest os with itunes. |
Error 9 change simtray 1000% solution ................give thanks |
have a solution for that in a new ios latest for error 53 just try to restore again and it will com back again to normal.... |
i have same problem with error 9 . my phone had a problem with camera and flash was disabled , i try to restore with itunes and now give error 9. i hope someone have solution ! |
error 9 its a hdd change it |
