Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 01-26-2015, 01:05   #1 (permalink)
Member: 2149341
Thanks Meter: 31
Iphone 6 error 9
I try to restore my iphone 6 always give me red screen and erreur 9 before its work fine plz i need you help
The Following 2 Users Say Thank You to Y0ussef12 For This Useful Post:
Old 01-26-2015, 02:21   #2 (permalink)
Member: 2149341
Thanks Meter: 31
Now it give me error 53 note the phone work fine before just sometime hang and restart any suggestion
The Following User Says Thank You to Y0ussef12 For This Useful Post:
Old 01-26-2015, 03:06   #3 (permalink)
Member: 1479956
with error 53 check fingerprint sensor...
Old 01-26-2015, 05:27   #4 (permalink)
Member: 2149341
Thanks Meter: 31
Its work fine before
Old 02-09-2015, 20:33   #5 (permalink)
Member: 678297
Thanks Meter: 4
Arrow iphone 6 error 53
Hi Youssef,
how did you solved first problem ( red screen and error 9) ? did you changed any part ?
anyhow error 53 occurs once you change sensor ID/ Home button
>>> so reinstall the old button
May this help you
The Following 2 Users Say Thank You to mtbh00GSM For This Useful Post:
Old 02-15-2015, 11:29   #6 (permalink)
Member: 2149341
Thanks Meter: 31
I solved my problem by removing the metal shield for lcd screen it solve error 9 & 53
Old 08-12-2015, 15:10   #7 (permalink)
Member: 363949
Thanks Meter: 20
same problem can anybody help in this after
removing the metal shield for lcd screen error 9 same occur
Old 12-18-2015, 06:55   #8 (permalink)
Member: 2427042
Thanks Meter: 7
put it in DFU mode and restore again.
Here's how.
INSTRUCTIONS
Step 1. Turn off iPhone
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that it’s in restore mode.
Alternative Method:
Step 1. Connect iPhone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Also a video.
[ame="http://www.youtube.com/watch?v=ROKCfzezGXw&feature=channel_page"]http://www.youtube.com/watch?v=ROKCfzezGXw&feature=channel_page[/ame]
This way you can determine if it's software or hardware.
Since you dropped it, might be broken.
The Following User Says Thank You to amit sagar For This Useful Post:
Old 12-19-2015, 08:44   #9 (permalink)
Member: 1031328
Thanks Meter: 22
bro please write here correct solution error 53 for i phone 6 its home button problm clean the connector or change the home button cable its 50% chance & red screen is the audio ic problem rie hot audio ic or change it its 100% solution
Old 04-12-2016, 11:55   #10 (permalink)
Member: 2092781
Sonork: family
error 9 and restart bootloop and when u try to restore stuck on waiting ur iphone then its hdd problem reheat or change it
Old 04-12-2016, 14:49   #11 (permalink)
Member: 2248295
Sonork: 100.1621465
Thanks Meter: 8
As per my knowledge error 53 (touch id senser/ home flex error) has been removed by apple. you just need to restore with the latest os with itunes.
Old 05-03-2016, 11:03   #12 (permalink)
Member: 2133026
Thanks Meter: 2
Error 9 change simtray 1000% solution ................give thanks
The Following User Says Thank You to rohit1155 For This Useful Post:
Old 05-23-2016, 13:25   #13 (permalink)
Member: 2259568
have a solution for that in a new ios latest for error 53 just try to
restore again and it will com back again to normal....
Old 05-26-2016, 17:06   #14 (permalink)
Member: 154346
Thanks Meter: 32
i have same problem with error 9 . my phone had a problem with camera and flash was disabled , i try to restore with itunes and now give error 9. i hope someone have solution !
Old 10-24-2016, 06:37   #15 (permalink)
Crazy Poster
Member: 935540
Thanks Meter: 19
error 9 its a hdd change it
The Following User Says Thank You to loranss For This Useful Post:
Page generated in 0.38518 seconds with 7 queries
