Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 08-24-2015, 15:29   #1 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 217
iphone 6+ update error 14
Phone was Password Disable
I just try to update the phone to 8.4.1
But every time it shows error 14
Now phone is in Recovery Mode.
i change pc, change cable
Any solution please.......
Old 08-24-2015, 17:06   #2 (permalink)
inamullah790000's Avatar
Member: 1985156
Sonork: 100.1652265
Thanks Meter: 313
Chek this https://support.apple.com/en-ap/HT204770
1. Delete the previously down*loaded software update file which you will find in this loca*tion depend*ing on your system:
Mac: /users//Library/iTunes/iPhone Soft*ware Updates
Windows XP: System Drive:/Doc*u*ments and Settings/Application Data/Apple Computer/iTunes/iPhone Soft*ware Updates
Windows 7: System Drive:/Users/Your Username/App Data/Apple Computer/iTunes/iPhone Software Updates
If you faced the error while upgrading your iPad or iPod, the last location path will change:
../iTunes/iPod Software Updates or ../iTunes/iPad Software Updates
2. Now, restart iTunes & begin the update again. This time iTunes will download a fresh copy of software update file.
If you’re trying to restore by using the downloaded iOS 8.4.1 IPSW file:
1. Re-download the IPSW file.
2. Now, restore to this newly downloaded IPSW file via iTunes.
All done
Chek hardware
Sent from my iphone 6 using Tapatalk - now Free
The Following User Says Thank You to inamullah790000 For This Useful Post:
Old 08-25-2015, 08:20   #3 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 217
thanks to all ....
problem solved
Old 08-25-2015, 15:59   #4 (permalink)
Crazy Poster
Member: 2314619
Thanks Meter: 7
how?????????????????????????????
Old 08-25-2015, 16:11   #5 (permalink)
Member: 2348459
I wish people would post what solution worked for them instead of saying "thanks, problem solved"
Old 08-25-2015, 16:38   #6 (permalink)
Member: 237628
Sonork: 100.1668254
Thanks Meter: 140
u can change lcd org anther phone then try
Old 08-26-2015, 12:56   #7 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 217
YOU ARE RIGHT.
i just connect the phone at recovery mode.
and click update (update the phone from Direct apple server)
not select manually Ipsw file by pressing SHIFT.
and job was done
The Following User Says Thank You to sanjoychy For This Useful Post:
Old 09-10-2015, 00:33   #8 (permalink)
Member: 1363143
Sonork: hassan
Thanks Meter: 3
Any have a solution for errore 19 iphone 6
Old 12-18-2015, 07:50   #9 (permalink)
Member: 2427042
Thanks Meter: 7
Check for hardware issues
Related errors: 1, 3, 10, 11, 12, 13, 14, 16, 20, 21, 23, 26, 27, 28, 29, 34, 35, 36, 37, 40, 1000, 1002, 1004, 1011, 1012, 1014, 1667, or 1669.
These errors mean that your device or computer may have a hardware issue that's preventing the update or restore from completing.
1.Check that your security software and settings aren't preventing your device from communicating with the Apple update server.
2.Then try to restore your iOS device two more times while connected with a cable, computer, and network you know are good.
3.Confirm that your security software and settings are allowing communication between your device and update servers.
4.If you still see the error message when you update or restore, contact Apple support.
Check for outdated or modified software
Related errors: 1015, “The required resource can't be found.”You might see these error messages if any of these are true:
•Your device has a beta version of iOS.
•You're trying to install an earlier version of iOS (downgrading).
•Your device has unauthorized modifications to iOS, also called "jailbreaking."
Use recovery mode to restore your device to the latest version of iOS.
Old 12-19-2015, 09:46   #10 (permalink)
Member: 1031328
Thanks Meter: 25
eny time i phone is update the itunes with server its good for the futer
The Following User Says Thank You to hasbullahar For This Useful Post:
Page generated in 0.18335 seconds with 9 queries
