10-12-2017, 05:23 | #1 (permalink) |
Junior Member Join Date: May 2017
Member: 2715901 Status: Offline Thanks Meter: 1 | iphone 6, intensity loop no boot I do have an iphone 6 plus for which I change the 2 touch ic components Since that, for an unanderstood reason, it does not boot anymore If i plug it to my 3.7v power suppply, i can see that the power supply react when i press the power button, the amps goes up and down without and and no reaction on the phone If i plug it to itunes, nothing happend until I force the dfu mode but then, it goes to 4005 error Thats weird I spent 10 hours to try to understand but I'm stuck I have changed U2 but still the same Of coure, I removed the two touch IC to check if I created a short but no... If someone has an idea... Thanks |
10-28-2017, 12:27 | #4 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Earth and around
Member: 1442842 Status: Offline Thanks Meter: 103 | Quote:
maybe you have worked with to high temperature and now you have a short under the CPU or other parts on the other side. But first remove the both Touch ICs . (The phone is able to start without the ICs ...) Maybe they defekt or shorted good luck! | |
The Following User Says Thank You to it-repair For This Useful Post: |
