Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 01-14-2017, 11:52   #1 (permalink)
Member: 1568729
iPhone 6s Plus Error 6
Hi everybody,
I got an 6s plus in bootloop. I tryed restore it in dfu und and restore mode...always getting error 6. Changed Battery and usb flex, nothing changend. Tryed also diffrent pcs/macs and usb cables.
Any ideas? What is error 6 related to? Is it Hardware issue? I didnt found many information on error 6 on the forum or even the web.
Thanks in advance!
Old 01-15-2017, 00:16   #2 (permalink)
Member: 1568729
No one? Cant belive theres no fix or even a advice where to move on
Gesendet von meinem SM-G930F mit Tapatalk
Old 01-16-2017, 11:37   #3 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 41
Hello
can you tell exactly when you got this Error during the restore process (at the end or at the beginning ).
Old 01-16-2017, 13:17   #4 (permalink)
Member: 1568729
Straight at the beginning. It isnt even moving a little Bit.
I tryed several times in dfu now and got error 9 which means bad nand right? Got 6 in restore mode and 9 in dfu any idea?
Old 01-16-2017, 13:25   #5 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 41
Ya that's what I was afraid of cause now it's complicated but before changing the NAND chip, check the battery connector if it's okay (not cracked).
Is there any water damage on the board??
Sent from my iPhone using Tapatalk
Old 01-16-2017, 14:23   #6 (permalink)
Member: 1568729
No water damage. Will check the connector later. But guess its nand theres no one in germany for this work so I guess its only for spareparts.
Thanks AYSER for your help!
Old 01-16-2017, 14:38   #7 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 41
I repaired one iPhone 6s Plus that had the same problem by reheating the NAND chip try it maybe it will work for you.
Best regards
The Following User Says Thank You to AYSER For This Useful Post:
Page generated in 0.17481 seconds with 8 queries
