06-24-2016, 11:41 | #1 (permalink) |
Insane Poster Join Date: Oct 2005
Member: 193584 Status: Offline Thanks Meter: 8 | iPhone 6 plus - Not turning on!! Help What I have done so far: - Changed big power IC (U1202) - Changed u2 ic (u1700) - Changed u1401 Checked all caps for short but all ok. No water damage signs also. Lines that I have tested, and have power: PP3V0_NAND PP1V8 PP1V2_NAND_VDDI PP_VCC_MAIN PP_CPU PP_LCM_BL_ANODE When I got phone, PC was detecting it, but clack screen, then after I remove the shields it wen't completely dead, and this is not first time I have removed it, so that should not be a problem. Does someone have any advice. I really need help here. Thank in advance |
06-28-2016, 17:07 | #5 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2529207 Status: Offline Thanks Meter: 5 | Have you check Q1701 fuse? Q1403? If U1202 and U1700 works it should work? check if Touchscreen ic is corroded? is your logicboard getting little bit warm? what is your voltage on PP_VCC_MAIN, and the others...? Last edited by nik001; 06-28-2016 at 17:16. |
The Following User Says Thank You to nik001 For This Useful Post: |
06-28-2016, 19:57 | #6 (permalink) | |
Member: 193584 Status: Offline Thanks Meter: 8 | Quote:
I have checked q1701 fuse and it's ok. I have changed q1403 also but it's the same. I get all correct voltage. Logic board is not getting worm. I have changed Touchscreen ic in the first place. Customer said that lcd was flickering and after time lcd went completely blank. I know that this is the problem in touchscreen ic, but I have changed it many times and repaired phone but in this one when I removed shields and changed touchscreen ic, phone died. It draws 0,49A from charger but not powering on. I have 1.8v on BUTTON_TO_AP_HOLD_KEY_CONN_L also. I really don't know what can be a problem. It is possible that I overheated CPU. I'm working with small nozzle and max 370c. How can I know that CPU is overheated? Last edited by esko1; 06-28-2016 at 20:05. | |
06-28-2016, 21:08 | #7 (permalink) |
Member: 2529207 Status: Offline Thanks Meter: 5 | No i think its not the CPU, this would be overheating... have you check your cpu ? you can check it on the voltage 1,2 volt .... but first check please the c1700 and c1704 and give me the voltage...? |
06-28-2016, 23:31 | #8 (permalink) | |
c1700...3.0v c1704...4.78v I really hope that CPU is not overheated. | |
07-05-2016, 06:07 | #12 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1637887 Status: Offline Thanks Meter: 2 | I have the exactly same problem with an i6+ here and I tried almost everything =( stuck at 0.05a and remains there. I noticed that a hard reset with power+home buttons works, so the cpu its working properly but might be a problem with the emmc (hdd) Did you solve it? |
07-22-2016, 17:18 | #13 (permalink) | |
Any solution for this? | |
07-26-2016, 10:01 | #14 (permalink) |
Member: 193584 Status: Offline Thanks Meter: 8 | ok I have now three iphones with the same error. PC not detecting it, I got 0.9v,1.2v, 1.5v, 1.8v, 3v...from Power IC, CPU and power ic is worm but, screen blank, draws 0.49A from charger...wtf is happening? Last edited by orx; 07-24-2018 at 22:00. |
