Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-22-2017, 12:57   #1 (permalink)
Member: 2516786
iPhone 6 plus only one line touch not work (changed ICs)
hi, i have a problem with iphone 6.
Other persons did a reflow with a lot of hot air for the touch ko.
i changed u2402 with a jumper in a pad, and now touch come back to works but one line no.
i reball u2402, changed again, changed u2401, same problem.. a vertical line not responds... (too with different display)
what could i do to check the problem?
thank you
Old 05-24-2017, 08:14   #2 (permalink)
it-repair's Avatar
Member: 1442842
Thanks Meter: 103
There is a row of capacitors between the both touch ICs. Take a look that all present, or that there is no short between the capacitors. In most cases that is the reason some lines on touch are not working
Old 05-27-2017, 13:58   #3 (permalink)
Member: 2516786
Thank you, I will check soon
Inviato dal mio E6653 utilizzando Tapatalk
Old 07-14-2017, 21:06   #4 (permalink)
Member: 2553311
Thanks Meter: 6
I´m facing the same problem now, have you repaired it?
Old 08-14-2017, 00:23   #5 (permalink)
Crazy Poster
Member: 2216247
Thanks Meter: 6
bro checl all caps between black ic and grey ic 100percent sure i solve a lot oh iphones with this problem
Page generated in 0.15395 seconds with 9 queries
