-   iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus (http://forum.gsmhosting.com/vbb/f933/)
-   -   iphone 6 restore error 4013 (http://forum.gsmhosting.com/vbb/f933/iphone-6-restore-error-4013-a-1950570/)
makaya pat 05-20-2015 14:16
iphone 6 restore error 4013 and blocked in itune logo !!!
please help !
ghazigohar 05-20-2015 22:43
Before You Start
As always:
Use the latest version of iTunes
Make sure iPhone has enough space to bring in a new update. A gig or more is recommended.
Also make sure the iPhone is not low on battery.
The Real Problem
Error 4014 (or 4013) is usually associated with a hardware problem Ė a faulty cable, a faulty port etc. On the surface, your iPhone connects to the computer, iTunes recognizes the device but somewhere down the line, iTunes thinks that the cable is not really that good. Or may be the port isnít.
The first thing you try should be change the USB port to which you connect the iPhone. Next up, change the cable that you use. Arguably, this has worked not for everyone but for a few people.
As an extreme measure, you can also try updating from some other computer which has the latest iTunes installed.
Backing Up and Going Into Recovery Mode
If you are trying to update the firmware without doing a clean restore but running into this error (even after changing the cables), itís time to cut the chase. This method is usually recommended as the last-thing-to-try but I think itís easier to get this done with right away.
Connect your iPhone to the computer. Fire up iTunes.
Backup your iPhone.
Now disconnect the iPhone, quit iTunes.
Put the iPhone in recovery mode. The short version goes like this: press and hold power and home buttons till the screen goes blank.
Open iTunes on PC.
Connect the iPhone. iTunes should indicate (through a dialog box) that an iPhone is detected in recovery mode.
Now go ahead and restore the device as new. This will erase everything but you will have the backup to restore from.
Some Notes
Occasionally, the error seems to vanish when people update to the last iOS 6.x version and then update to iOS 7. (This applies when you are on iOS 6.0, 6.1).
Clear out apps and app memory to free up space on your iPhone. Although this sounds very unrelated to this error, it has helped.
sasan500 06-05-2015 02:27
sometimes it happens wen u use a after market part on the phone. open the phone and check what had been changed. change it back with the original part, u'll be just fine. the most common part for this error is the screen or sensor. so restore the phone without screen or sensor to see if its working or not and let me know!!
ElioHammer 10-08-2018 10:12
follow the below methods to check and fix the iTunes error 4013 issue
check the computer
check the USB cable/port
check the Wi-Fi
hard reset your iPhone
third party tool
bobo bokota 10-08-2018 20:44
Reprogram nand
Envoyť de mon iPad en utilisant Tapatalk
dotnetfix 10-09-2018 01:58
1- nand reballing
or programe nand otherwise change nand.....
Amanda0820 10-10-2018 09:44
to save iphone 6 restore error 4013 and seeking for logic board solution, you can rule out some basic causes first as following:
1. Update iTunes to the latest version.
2. Update your computer to the latest OS.
3. Restart your computer and soft reset your iOS device.
4. Unplug and plug in your iOS device to try again.
Error Code 4013, 4014
Check the condition of CPU power supply or components on power supply rails.
Check if the CPU is pseudo soldered or damaged.
https://blog.rewatechnology.com/wp-c...6-6plus-03.jpg
Gabidauri11 10-10-2018 10:29
download itunes and flash this phone :))
kunal124 11-13-2018 07:20
check capactiors and itz voltage beside nand...and remove shorted capatiors..hope this might help you
[email protected] 12-07-2018 23:52
hi
which sensor you mean here and where is it located?
Page generated in 0.25558 seconds with 5 queries
