Iphone 6 strang problem Iphone 6 stuck in DFU mode.When i try to restore this phone it's showing error is software for this iphone is not currently available.make sure you have the latest version of iTune and try again. but my iTune is up to date and latest os version trying to restore. I dont know what is really problem.hardware or software.motherboard is untouch. :confused: |
please any one master? |
did you replaced the lcd ? after that u got this problem ? |
it is a hardware problem...need to change the U2 IC |
NO......... untouch phone.fresh phone. |
this is hardware problem for sure... |
i try both,also change computer and window and mac also. |
In Case restoring did not work even with Alt option key that's means it's hardware. i had the same issue and apple swap the phone for me. |
I have the same issue with an iphone 6 Plus.I got this "software for this iphone is currently not available.Make sure you have the latest version of itunes & try again."After an iphone 6 plus was dropped and got a red screen/Error 4013..I tried to reball the Audio IC and after since when I connect it to itunes it says so & the iphone 6+ stuck in DFU mode...Any idea or suggestion is appreciated-thank you! |
Is hardware problem baseband or memory IC |
I have also same problem not solved but my iPhone6 I water damage |
Same issue with me . Water damage phone same issue |
stuck in itunes Quote:
