Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 04-01-2015, 09:44   #1 (permalink)
Member: 656076
Thanks Meter: 5
Iphone 6 strang problem
Iphone 6 stuck in DFU mode.When i try to restore this phone it's showing error is software for this iphone is not currently available.make sure you have the latest version of iTune and try again.
but my iTune is up to date and latest os version trying to restore.
I dont know what is really problem.hardware or software.motherboard is untouch.
Old 04-04-2015, 12:02   #2 (permalink)
Member: 656076
Thanks Meter: 5
please any one master?
Old 04-04-2015, 12:38   #3 (permalink)
Cheater -Don't Deal with him-
Member: 390492
Thanks Meter: 66
did you replaced the lcd ? after that u got this problem ?
Old 04-04-2015, 14:37   #4 (permalink)
Member: 126801
Thanks Meter: 23
it is a hardware problem...need to change the U2 IC
Old 04-08-2015, 14:44   #5 (permalink)
Member: 656076
Thanks Meter: 5
NO.........
untouch phone.fresh phone.
Old 04-10-2015, 14:25   #6 (permalink)
Member: 2376753
this is hardware problem for sure...
Old 04-10-2015, 17:39   #7 (permalink)
Member: 1229161
Sonork: 100.1678008
Thanks Meter: 18
did you choose the firmware by manually or you let itunes choose ?
Old 04-14-2015, 07:41   #8 (permalink)
Member: 656076
Thanks Meter: 5
i try both,also change computer and window and mac also.
The Following User Says Thank You to m zone For This Useful Post:
Old 06-27-2015, 15:59   #9 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
In Case restoring did not work even with Alt option key that's means it's hardware.
i had the same issue and apple swap the phone for me.
Old 06-27-2015, 23:49   #10 (permalink)
Member: 2398349
Thanks Meter: 61
whatever it is, its hardware problem. if u didn't open the phone, just have apple change it for u!!
The Following User Says Thank You to sasan500 For This Useful Post:
Old 03-30-2016, 04:01   #11 (permalink)
beneto's Avatar
Member: 148833
Thanks Meter: 25
I have the same issue with an iphone 6 Plus.I got this "software for this iphone is currently not available.Make sure you have the latest version of itunes & try again."After an iphone 6 plus was dropped and got a red screen/Error 4013..I tried to reball the Audio IC and after since when I connect it to itunes it says so & the iphone 6+ stuck in DFU mode...Any idea or suggestion is appreciated-thank you!
Old 08-29-2016, 11:57   #12 (permalink)
Member: 467983
Thanks Meter: 14
Is hardware problem baseband or memory IC
Old 09-07-2016, 02:42   #13 (permalink)
Member: 2601267
I have also same problem not solved but my iPhone6 I water damage
Old 09-07-2016, 07:12   #14 (permalink)
Hamid memon786's Avatar
Member: 2255989
Sonork: 1001675246
Thanks Meter: 46
Same issue with me . Water damage phone same issue
Old 09-09-2016, 14:50   #15 (permalink)
Member: 614239
Thanks Meter: 9
Thumbs up stuck in itunes
water locked phones has been stuck in itunes logo first check whether the phone will ping with your laptop with installing the drivers. if not means change the U2 ic .
Page generated in 0.32948 seconds with 7 queries
