Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 09-20-2016, 00:59   #16 (permalink)
Member: 2626661
Originally Posted by flip_gsm View Post
Is hardware problem baseband or memory IC
hi, anything on that?
Old 09-20-2016, 19:16   #17 (permalink)
hardboy's Avatar
Member: 863309
Sonork: 4540726
Thanks Meter: 41
Please try 3utools and remember last version iOS is 10.0.1
Old 12-02-2016, 12:50   #18 (permalink)
Member: 1866517
Originally Posted by Gago_ View Post
did you replaced the lcd ? after that u got this problem ?
Yes dfu mode "software not available for this iphone"
after change lcd screen. Any solution?
Old 03-17-2017, 20:32   #19 (permalink)
Member: 1839857
Thanks Meter: 46
This is for sure nand problem, just fixed a 6+ with this problem by reballing the nand. I checked the nand in my programmer and everything was ok, so soldered it back in and phone was back alive.
Old 03-30-2017, 10:30   #20 (permalink)
Member: 2403795
my iphone 6 dead after lcd replace so please any solution experts..
Old 04-03-2017, 13:31   #21 (permalink)
Member: 2115441
Hi!
Did anybody find the solution!
I also have a very slight water damaged iPhone 6 (only top of the phone has small trace of water) I have cleaned and when i plug in to my laptop, iTunes detect him in DFU mode and when I try to restore - "software for this iphone is not currently available."
Thank you!
Old 04-04-2017, 10:43   #22 (permalink)
hardboy's Avatar
Member: 863309
Sonork: 4540726
Thanks Meter: 41
Try 3uTools flash and write error if not works
Old 04-04-2017, 10:53   #23 (permalink)
Albelektronik's Avatar
Member: 178513
Thanks Meter: 109
Did the iTune give any error number? did You try as well with 3U Tool? Give us more details. Pls for others to create their owen thread and not creating confusion...
Thnx.
Old 04-04-2017, 11:32   #24 (permalink)
Member: 2115441
Thank's
I didn't' open a new threat as i guess is the same problem!
3uTools see it in DFU mode and give me the following error "unable to detect iDevice product type".
Old 04-04-2017, 11:33   #25 (permalink)
Member: 178513
Thanks Meter: 109
Did You try if any capacitor in short around NAND IC?
Old 04-04-2017, 11:47   #26 (permalink)
Member: 2115441
Yes and no short in capacitors
Actually i don't find any short on the motherboard!
Old 04-04-2017, 20:02   #27 (permalink)
Member: 178513
Thanks Meter: 109
Maybe the NAND IC than, is just a suspect as i not faced never a problem like this.
Sent from my iPhone using Tapatalk Pro
Old 04-05-2017, 08:12   #28 (permalink)
Member: 2115441
I notice that the processor or on the back of the processor around PM IC (i can't tell which one) is getting a little bit hot when is connected to pc.
Old 04-18-2017, 05:28   #29 (permalink)
Member: 1225078
Thanks Meter: 10
The iTunes is not recognizing the phone properly so it says that phone firmware is not available. It's very likely to be nand problem you need reball it. There is an import information of phone model that is recorded on nand ic.
Old 04-23-2017, 23:26   #30 (permalink)
Member: 2628090
Thanks Meter: 7
Board allways gets hot little bit if its powering on. If you cant hold finger on it then its shorted
Page generated in 0.21724 seconds with 8 queries
