Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 09-02-2015, 12:51   #1 (permalink)
Crazy Poster
Member: 2345217
Thanks Meter: 6
iPhone 6 stuk on searching
iPhone 6 stuk in searching
modem ok
imei ok
plz help
The Following User Says Thank You to __jasad__ For This Useful Post:
Old 09-02-2015, 14:58   #2 (permalink)
Member: 2427042
Thanks Meter: 7
its repaired before with hardware ??
The Following 2 Users Say Thank You to amit sagar For This Useful Post:
Old 09-02-2015, 16:03   #3 (permalink)
Crazy Poster
Member: 2345217
Thanks Meter: 6
i think idevice refresh
meybe repaired
Old 09-02-2015, 16:15   #4 (permalink)
saifjaan009's Avatar
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 353
Check Date And Time
__________________
Please Don't Break Rules
BR;
..:: Saif Ur Rahman ::..
The Following User Says Thank You to saifjaan009 For This Useful Post:
Old 09-02-2015, 19:09   #5 (permalink)
Crazy Poster
Member: 2345217
Thanks Meter: 6
time and date ok
i think this problem hardware
plz solution
Old 12-16-2016, 11:16   #6 (permalink)
Burnt Toast's Avatar
Member: 2499740
Thanks Meter: 11
Try a liquid bath for 1/2 an hour then try again
Old 12-19-2016, 06:04   #7 (permalink)
Member: 2655669
Thanks Meter: 6
Hard reboot your iPhone.
Press and hold down "Wake/Sleep" and "Home" buttons at the same time until the screen gets black.
Old 12-25-2016, 13:08   #8 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 32
This is a common problem in iPhone 6 devices. Follow these steps:
1- Check the network antenna ( comes with USB Dock Flex)
2- Change the USB Dock Flex.
3- Check the Network Power Management IC if its cracked or damaged, resolder or replace.
ASM IC , 2G IC, Transceiver IC .... could cause this problem but you can get the full troubleshooting with the solution picture here:
(SFS Service. TSA Master Technology) download the SFS software and use it,
all the solutions are well explained.
Old 06-26-2017, 18:38   #9 (permalink)
Member: 2730822
Thanks Meter: 2
hello bro
dial *#06# if not appear imei
baseband ic problem
make reball the ic
post result
Page generated in 0.26980 seconds with 7 queries
