11-26-2018, 16:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2126418 Status: Offline Thanks Meter: 8 | iphone 6 work only on power supply I have iphone 6 that come with charge problem I replace u1700 after that the phone work on power supply with out any problem but with battery do restart loop. I change and u1401 and q1403 and still the same with power supply all ok but with battery boot loop I try 3 batteries and original too. Also current draw is under 10ma in stby |
01-29-2019, 02:59 | #2 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | Maybe the charging port is full of dirt or the cables may be damaged. Also, a software or hardware issue can cause your iPhone 6 charge problem. There have some solution about iPhone 6 charging problem as following: 1. Restart iPhone 2. Update iOS Go to Settings Tap General Tap Software Update Tap Download and Install 3. Clean the iPhone’s charging port 4. Try another charging and USB port 5. Charging fault analysis 6. Charging fault detection 7. Detection and troubleshoot |
