11-12-2015, 21:26 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Iphone 6S Chipgate Explained! Determine the Manufacturer: TSMC or Samsung An easy way to determine which manufacturer made the chip running on a particular Apple device is through the free iOS app called Lirum Device Info Lite. For the iPhone 6s, if Lirium identifies the chip as N71mAP, then it was made by TSMC and if it displays N71AP, then it is from Samsung. The same is true for the iPhone 6s Plus. TSMC's chips will have N766mAP and Samsung's will be displayed as N66AP. So what's the big deal if they came from different manufacturers? One of the first ones to tell highlight the different chips running on Apple's latest iPhone models is Chipworks, which reported that TSMC's A9 chip is bigger than that of Samsung's by about 8.5 mm2. This is courtesy of TSMC using a 16nm FinFET process while Samsung used its 14nm LPE FinFET technology. However, the issue grew bigger because of a Reddit post by user pw5a29, who said that he happened to have "2 6S Pluses (64GB) on hand with one being a TSMC chip and the other a Samsung chip." The Redditor then proceeded to discuss the difference in battery consumption. "The TSMC chip was able to last for almost eight hours," wrote pw5a29. "While the Samsung chip was only able to achieve approx. 6 hours." Some have raised issues on the testing method that pw5a29 used since one iPhone had a SIM card and data was also running while the other one did not have any. In the interest of science and getting to the truth of this issue, a lot of Apple-centric and tech-oriented communities, publications and YouTube channels have tested this out. Ars Technica published its comparison of the TSMC and Samsung chips. And although there was hardly any difference for tasks that only utilized 50-60 of the chips' compute power, TSMC's still edged Samsung's A9 SoC. The bigger discrepancy came when processor-taxing apps like Geekbench 3 are run. YouTuber Jonathan Morrison also reported a 5-7 percent difference in battery life, which depended on tasks performed, in favor of TSMC. Austin Evans also did his own testing and revealed a significant battery life advantage for the TSMC on heavy phone usage. "Our testing and customer data show the actual battery life of the iPhone 6s and iPhone 6s Plus, even taking into account variable component differences, vary within just 2-3 percent of each other," said Apple. Consumer Reports has recently published an article that supports Apple's claim. So who do you believe, Apple and Consumer Reports or the other three? Below is Marques Brownlee explaining, in a calm and collected manner, that while it is advantageous to score a TSMC chip, the "chipgate" issue is hardly an issue for average users. https://www.youtube.com/watch?v=m1fUil7QLNI Source:techtimes |
