01-14-2017, 11:52 | #1 (permalink) |
Junior Member Join Date: May 2011
Member: 1568729 Status: Offline Thanks Meter: 0 | iPhone 6s Plus Error 6 I got an 6s plus in bootloop. I tryed restore it in dfu und and restore mode...always getting error 6. Changed Battery and usb flex, nothing changend. Tryed also diffrent pcs/macs and usb cables. Any ideas? What is error 6 related to? Is it Hardware issue? I didnt found many information on error 6 on the forum or even the web. Thanks in advance! |
01-16-2017, 13:17 | #4 (permalink) |
Member: 1568729 Status: Offline Thanks Meter: 0 | Straight at the beginning. It isnt even moving a little Bit. I tryed several times in dfu now and got error 9 which means bad nand right? Got 6 in restore mode and 9 in dfu any idea? Gesendet von meinem SM-G930F mit Tapatalk |
01-16-2017, 13:25 | #5 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2136572 Status: Offline Sonork: 100.1653162 Thanks Meter: 41 | Ya that's what I was afraid of cause now it's complicated but before changing the NAND chip, check the battery connector if it's okay (not cracked). Is there any water damage on the board?? Sent from my iPhone using Tapatalk |
01-16-2017, 14:23 | #6 (permalink) |
Member: 1568729 Status: Offline Thanks Meter: 0 | No water damage. Will check the connector later. But guess its nand theres no one in germany for this work so I guess its only for spareparts. Thanks AYSER for your help! Gesendet von meinem SM-G930F mit Tapatalk |
01-16-2017, 14:38 | #7 (permalink) |
Member: 2136572 Status: Offline Sonork: 100.1653162 Thanks Meter: 41 | I repaired one iPhone 6s Plus that had the same problem by reheating the NAND chip try it maybe it will work for you. Best regards Sent from my iPhone using Tapatalk |
The Following User Says Thank You to AYSER For This Useful Post: |
