08-09-2017, 10:42 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: HongKong
Member: 2494453 Status: Offline Thanks Meter: 200 | You Can Experience iOS 11 Beta 5 on 3uTools for your iPhone 6 Now you can upgrade to iOS 11 Beta 5 on 3uTools. As always, remember to backup on 3uTools your iDevice before you flash it. Step 1: launch the latest 3uTools and connect your iDevice to your PC with USB cable. Step 2: Click "Flash & JB" -> "Easy Flash", then select the firmware iOS 11 Beta 5 as the following picture. (If you want to save your data, please select the option "Retain User's Data While Flashing") Step 3: During the process of flashing, keep a good connection between your iDevice and your PC. And then wait patiently till the process finishes. (Normally, it takes several minutes) Wait till flash is done, and you can experience the new features of iOS 11 Beta 5 which are mentioned before. Check original post on 3uTools you would find more: You Can Experience iOS 11 Beta 5 on 3uTools - 3uTools |
The Following User Says Thank You to Supermarios For This Useful Post: |
