07-02-2015, 20:39 | #1 (permalink) |
No Life Poster Join Date: May 2015 Location: Los Angeles
Member: 2398349 Status: Offline Thanks Meter: 62 | True Story about iPhone's iCloud Lock I opened a thread to discuss about iCloud lock and to learn is it true to be removed by hardware or not. what I understand about iCloud lock is that apple server lock the phone's IMEI with a Email and in order to activate it, you have to use the key which is that Email address to unlock the phone, so whatever you do, in the end you have to activate the phone's IMEI with apple server to get it work and the phone is lock with same IMEI and same Email address. So it has nothing to do with the phone and hardware and only and the only way to turn this around is to change the IMEI which is impossible right now. So when people say they did it with hardware, how they really do it or what do they mean by that!! |
07-05-2015, 03:41 | #2 (permalink) | |
Junior Member Join Date: Jun 2015
Member: 2411032 Status: Offline Thanks Meter: 0 | Quote:
07-05-2015, 06:14 | #3 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1594608 Status: Offline Thanks Meter: 20 | wifi model ipad u can reprogram NAND to other SN it's mean icloud remove . cellular and wifi model ipad u need to give up cellular to bypass icloud (facetime and push not working ). |
07-23-2015, 12:54 | #7 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Germany
Member: 2105007 Status: Offline Thanks Meter: 40 | it was always possible to unlock an Iphone with swapping all baseband and serial realated ic from a dead (and unlocked) board with an icloud locked one. Same with Ipads (tho models and ways to unlock differ) But since it is so freaking time consuming and so many things can go wrong,ppl just do not do it. I would have to charge you so much money for my work that you could go ahead and buy a new phone. Since icloud is such a huge problem and many ppl are desperate there are many scams about the IMEI unlock premium service, but yes both ways work, they are just expensive. |
The Following User Says Thank You to jackie8 For This Useful Post: |
07-27-2015, 18:45 | #8 (permalink) | |
Member: 2398349 Status: Offline Thanks Meter: 62 | Quote:
08-11-2015, 08:13 | #9 (permalink) |
Junior Member Join Date: Jan 2005 Location: Maldives Age: 44
Member: 102878 Status: Offline Thanks Meter: 0 | How to find iculoud username If after restore customer don't know the icloud user name. he cant recover that form also. so how we can know his icloud user name by imei? any solution? |
08-11-2015, 21:33 | #10 (permalink) | |
Member: 2105007 Status: Offline Thanks Meter: 40 | Quote:
here you find an example how it works on iphone 5 icloud unlock by hardware: https://www.youtube.com/watch?v=wf1SVk8YIFk | |
08-23-2015, 18:57 | #14 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | I tried 2 times to remove icloud Swapped bb cpu, eeprom ic and nand ic from dead board. I soldered them on icloud locked ip 6. but i am not sure if i should take eeprom ic because it tells nothing about serial or imei in schematics like the other iphones. Anyways i had both times error 53. even with home button from same cpu. And there is nobody who can confirm that it is possible. But it is much more easier than orher iphones to replace those ics. If somebody has ever do this i aporeciate if he tell which ics. |
