07-03-2018, 07:57 | #1 (permalink) |
Insane Poster Join Date: Oct 2015
Member: 2472927 Status: Offline Thanks Meter: 12 | iCloud Dose Not Remove permanently iPhone 4 !! I Removed icloud iphone 4 without active iphone [info] [info] Starting ... [info] Loading required libraries ... [info] Adding 'C:\MFC' to DLL Search path ... [info] Adding 'C:\Program Files\Common Files\Apple\Apple Application Support\' to DLL Search path ... [info] Adding 'C:\Program Files\Common Files\Apple\Mobile Device Support\' to DLL Search path ... [info] Adding 'C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\' to DLL Search path ... [info] Found device in DFU mode [info] Identified device as iPhone 4 GSM, n90ap, iPhone3,1 [info] connecting to DFU [info] Exploiting bootrom... [done] Exploit sent! [info] Please reconnect your device now if it does not happen automatically! [info] DFU Connect [info] Waiting for device to come online ... [info] DFU Disconenct [info] DFU Connect [info] Running DFU Restore ... [info] DFU Disconenct [info] Recovery Connect [info] Running Recovery Restore ... [info] Recovery Disconnect [info] Apple device arrival ... searching USBMux for device after 100ms [info] Starting ... [info] Running on port 22 [info] Connecting... [info] Mounting filesystem... [info] Reading accounts data... [info] Finished backing up 3 files in 0 dirs [info] Operation done successfully [warn] No data found. [info] Backing up files... [info] Finished backing up 6 files in 2 dirs [info] Finished backing up 0 files in 0 dirs [info] Patching... [info] Rebooting device... [info] Apple device disconnected! [info] Searching for iDevice ... [info] Found device in Recovery mode [info] Identified device as iPhone 4 GSM, n90ap, iPhone3,1 [info] changing mode ...[info] RECOVERY->NORMAL.. [info] device serial number is 86129C03A4T [warn] operation not defined! [done] Operation finished. Bye bye! and i access To Phone ( i can do every thing means i can sign in my apple id to iTunes and icloud section without problem ) but when reset the phone Activation Lock Still exist (Previous apple id) what can i do for fix ? And second Question is Phone did not any network Before Bypass (was no service) IS The Solution For It? THX A LOT |
07-03-2018, 12:17 | #2 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144374 Status: Offline Thanks Meter: 64 | Hi. Bro read service manual https://www.mfcbox.com/manual/#features/83 |
07-03-2018, 14:24 | #3 (permalink) | |
Member: 2472927 Status: Offline Thanks Meter: 12 | Quote:
Would u just tell me why icloud is active After bypass? | |
