04-29-2017, 21:23 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | So if you can update to IOS 7 , then you can unlock that by MFC dongle for sure. |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
05-05-2017, 13:38 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | u are right "if i can" but is look that is not possible, i try via itunes to update to ios 7.0x and it say that is not the right firmware for my device but im sure 100% that is right or error 3194 |
05-07-2017, 06:58 | #7 (permalink) |
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | itunes error 3194 and flash via mfc [info] [info] Starting ... [info] Using LOCAL IPSW E:\gsm\flash files\APPLE\IPAD 3RD\iPad3,3_7.1.2_11D257_Restore.ipsw [info] Loading version data from Apple Server [info] Updated version data. [info] Found device in Recovery mode [info] Identified device as iPad 3 GSM, j2aap, iPad3,3 [info] Extracting BuildManifest from IPSW [data] Product Version: 7.1.2 [data] Product Build: 11D257 Major: 11 [info] device serial number is DLXH52RPDVGK [data] Device supports Image4: false [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Found ECID 3679446658344 [info] Getting ApNonce in recovery mode... [data] F79491DB6E7F0905FD3FCDD32526C8F91A5A659E [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [erro] TSS server returned: STATUS=94&MESSAGE=This device isn't eligible for the requested build. [erro] TSS request failed (status=94, message=This device isn't eligible for the requested build.) [erro] tts>Unable to send TSS request [erro] Unable to get SHSH blobs for this device [info] Failed |
05-07-2017, 12:06 | #8 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | [erro] TSS server returned: STATUS=94&MESSAGE=This device isn't eligible for the requested build. [erro] TSS request failed (status=94, message=This device isn't eligible for the requested build.) This mean the version of this already stop sign, So can not via this version. As i remember there is some software named odysseus, maybe can help you , but this also required the shsh backup file. if this device jailbreak before , maybe can download the shsh file from cydia. |
