06-01-2018, 07:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2120342 Status: Offline Thanks Meter: 25 | IPHONE 5S Flashing error [info] Starting ... [info] Using LOCAL IPSW D:\3uTools\Firmware\iPhone_4.0_64bit_11.4_15F79_Re store.ipsw [info] Loading version data from Apple Server [info] Updated version data. [info] Found device in Recovery mode [info] Identified device as iPhone 5s, n51ap, iPhone6,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 11.4 [data] Product Build: 15F79 Major: 15 [info] device serial number is F17MDDQ0FFFL [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 8486603829808 [info] Getting ApNonce in recovery mode... [data] 62B3FB3F8A1C23640A547F5EC1AAD9EA0C2224F7 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 4FA8A4FB1287557E074602BA47F377848B79B5C3 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting filesystem [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.iphone6.RELEASE.im4p... [info] Sending iBEC (710360 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.60.11 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@2x~iphone.im4p... [info] Sending AppleLogo (11639 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-10014-091.dmg... [info] Sending RestoreRamDisk (79318038 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n51ap.im4p... [info] Sending RestoreDeviceTree (108144 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.iphone6... [info] Sending RestoreKernelCache (13465573 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device df60245c4380891596edfcdeb7c8e49561c2547f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 0 [info] ChipID: 35168 [info] UniqueChipID: 8486603829808 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49157) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.iphone6.RELEASE.im4p... [info] Extracting applelogo@2x~iphone.im4p... [info] Extracting batterycharging0@2x~iphone.im4p... [info] Extracting batterycharging1@2x~iphone.im4p... [info] Extracting batteryfull@2x~iphone.im4p... [info] Extracting batterylow0@2x~iphone.im4p... [info] Extracting batterylow1@2x~iphone.im4p... [info] Extracting glyphplugin@1136~iphone-lightning.im4p... [info] Extracting DeviceTree.n51ap.im4p... [info] Extracting recoverymode@1136~iphone-lightning.im4p... [info] Extracting iBoot.iphone6.RELEASE.im4p... [info] Extracting sep-firmware.n51.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [erro] Unable to receive message from FDR 06C13E18 (-4). 0/2 bytes [info] Apple device disconnected! Plz help me |
