02-16-2015, 09:48 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 539679 Status: Offline Thanks Meter: 468 | iphone 6 ios 8.0.2 Mfc proper guide (HELP) every i put mfc together with the 3 in 1 otg cable after reboot iphone screen like this waithing hour tooo long .. now put active simcard can see original waithing hour after waithing phone go back to input code status . then put back again MFc same again waithing too long status repaet again and again. My Mfc wiring. image hosting no register photo uploader video demo wiring. https://www.youtube.com/watch?v=aaDzU6THVKI after reboot check the charging is stop also. error https://www.youtube.com/watch?v=g8VUplDDBVs Last edited by rodbautis; 02-16-2015 at 09:53. |
The Following User Says Thank You to rodbautis For This Useful Post: |
02-16-2015, 11:38 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Micro USB input power you need connect always, MFC Dongle takes power only from Micro USB If the phone reboot always, but have not input the code, then please in the Micro input power if 5V/1-2A |
02-16-2015, 15:03 | #3 (permalink) |
Member: 539679 Status: Offline Thanks Meter: 468 | the micro input power always there if i do the operation... the problem is everytime iphone 6 reboot the screen or iphone status is waithing thousand minutes. put active sim became normal yes i do it........ back to input code status now put mfc then otg 3 in 1 iphone reboot after that again thousand minutes waithing status again. |
02-16-2015, 16:19 | #4 (permalink) |
Insane Poster Join Date: Feb 2015
Member: 2345450 Status: Offline Sonork: 100.1605447 Thanks Meter: 9 | yes,me too i read instruction very carfully and and follow how to connect by pic supporter post too after connect all then iphone 6 reboot then show 23xxxxxxxxxxxxxxx mn then phone restart again and again still show Disabled and wait 23xxxxxxxxxxxxxx mn. always i use Micro USB input power 5v 1A from my ipad. what problem?pls help supporter |
The Following User Says Thank You to chan_rattanak For This Useful Post: |
02-16-2015, 18:17 | #5 (permalink) | |
Member: 539679 Status: Offline Thanks Meter: 468 | Quote:
please help us sir i dont want to loose this i want to fix this to earn atleast 1 unit to cover my mfc payment. | |
02-18-2015, 11:56 | #14 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | if put the active sim, i am sure after 1st boot , the time will be back to normal, then the start will be continue , i hope all the use read the instructions about the delay time , which only for your phone was disabled, the other words which mean if your phone not disable yet, then you need to set the delay time is 0. thanks BR, Denis |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
02-19-2015, 07:10 | #15 (permalink) |
Member: 539679 Status: Offline Thanks Meter: 468 | iphone 6 on my obserbation .... thats why the millions minutes waithing always come out because mfc reboot the iphone cut the power totally then on screen appear millions minutes again ... i try w/o Mfc remove battery from iphone then the millions minutes come put active sim to correct the date and time back to normal i mean passcode input status.even on and off iphone still normal but if battery remove or power cut now millions minutes come again. now Mfc how to put permanent power in the iphone because everytime put mcf and otg cable phone will reboot totally cut the power . |
