Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle
Old 10-26-2014, 18:55   #1 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Sonork: Wechat ID: gsmdenis
Thanks Meter: 4,700
MFC Dongle Initial Setup Full Instructions (04-20 Update sensor and Alphabet) ★★★★★
THE RIGHT TOOLS MAKES A DIFFERENT, THAT'S MFC
(Click On the image View Online - Update at 2015-4-30)
To Read this manual, suggest using Firefox browser. You can download from https://www.mozilla.org/en-US/firefox/all/
Old 10-26-2014, 19:13   #2 (permalink)
Member: 79315
Thanks Meter: 4,700
Can't use the read or write settings ?
Please check:
  • MFC dongle is correctly connected to computer. On some computers you need to use the USB to USB adaptor in order for Windows to detect the dongle correctly.
  • MFC dongle drivers are correctly installed (check again the first section and uninstall the software if needed)
Old 11-25-2014, 11:04   #3 (permalink)
Member: 79315
Thanks Meter: 4,700
A simple guide to know the dongle work or not work:
Sometimes when we unlocking phone by MFC, you may wanna to know If the dongle in working condition.
Here is the testing guide
When you unlocking:
You may covered the sensor by sponge or some tape.
A, Remove sponge or tape , and remove the sensor form the cable. give some light to the sensor, then dongle LED light will be get very fast blinking mode.
B, Now the dongle will be stop sending command to phone
C, Remove the USB cable from the phone
D, Insert the dongle to computer, press read
E, Check the last index value from logs if get change
Now you will know the Dongle If in working condition.
The fast way to unlock your phone ,Here have some way may help you :
A, If you know your phone code maybe 2xxx
Then you can setting the start value with 2000
B, If you know your phone code between 2500 -3000
You can using above A method, you also can setting your start value is 3000, and click on DESCENDING ORDER
The Following 6 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 12-09-2014, 06:27   #4 (permalink)
Member: 79315
Thanks Meter: 4,700
Arrow MFC Dongle Repair tools v3 Released ! (2014-12-10)
@ALL,
Due some customer did mistake when they updating the dongle and facing the error is :
Failed to load update from update server!
We make a new Repair tools software for this!
How to use:
  • Download Repair tools at support page at here
  • Open the tools and Put your dongle in boot mode
    • BOOT MODE you need to connect P0 and GND(P zero) pin together (see images below) using the RED cable we provided in the pack.
  • Input your dongle to computer USB port. This message you will got:
    [info] > Program started!
    Please input first your serial number as it appears on the serial number sticker!
    [warn] FW 23 Please connect your MFC Dongle using BOOT MODE only!
    [sett] Please input a correct sticker serial number!
  • Input the correct sticker serial number from the package
  • Follow the step disconnect and reconnect the dongle to repair
    Please connect MFC Dongle in BOOT MODE to continue...
    [info] Current SN: 0xYour bad S/N FW: 2.0
    [warn] The sticker SN and the Current SN does not match! Checking ...
    [info] connecting...
    [warn] > Waiting for reconnect...
    [warn] > Erasing ...
    [done] OK
    [info] Please wait ...
    [done] Step 1/16 - Please disconnect and connect MFC Dongle again...
    [done] OK
    [done] Step 6/16 - Please disconnect and connect MFC Dongle again...
    [info] Current SN: 0xYour Orignal S/N FW: 2.1
    [done] The SN might have been repaired successfully! Please try to use your dongle now!
Now your dongle got repaired.
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post:
Old 12-12-2014, 11:44   #5 (permalink)
Member: 79315
Thanks Meter: 4,700
About automatically increase / adjustment your device brightness
Some device the Display /brightness very Lower, This will casing even your device unlocked, but dongle LED still not get fast blinking mode. So you may miss the corrected code when you unlock.
About iPhone we can using iOS 7.1.2 auto v2.3 to auto adjust the brightness. But some device like iPad maybe with out SIM slot, so the problem when we unlock , we can not Go to Emergency call screen. Here is The method was like this:
A. Using iOS 7.1.2 auto v2.3 update your dongle at first
B. Connect your dongle (without sensor) to your device to increase the brightness
C. Using iOS 7.1.2 auto v2.2 update your dongle
D. Now back to unlock
Old 12-22-2014, 03:20   #6 (permalink)
Member: 79315
Thanks Meter: 4,700
MFC dongle has two modes:
  • NORMAL
  • BOOT
NORMAL for settings / Sensor test / Read code etc.
BOOT for update and repair.
-Normal Mode
-Boot Mode
Old 12-22-2014, 04:18   #7 (permalink)
Member: 79315
Thanks Meter: 4,700
About MFC Dongle unlock code /LED /Sensor etc
When you can get correct unlock code ?
  • Once unlock process is done, Phone will go to home screen, and MFC Dongle 2 LEDs will be activating in fast blinks mode.
E.g. 0115 is the latest code you read via software. If the sensor did not stopped the process in time then the real code might be before that so you need to try 0114 0113 ... You can also use MFC dongle and setting the start value from 0115 (and click the descending order checkbox) and you will find the code maybe faster than trying yourself.
Light sensor right position on device screen and must be overcurtain
Here have some video please check:
http://www.youtube.com/watch?v=-hQoF8hBDI4
http://www.youtube.com/watch?v=p6LuhzD6yC0
http://www.youtube.com/watch?v=VHngHdzGOjY
http://www.youtube.com/watch?v=e9Io_59itAg
http://www.youtube.com/watch?v=XoLR6MJM-6g
http://www.youtube.com/watch?v=WrEzD4DF7ps
The MFC dongle tries codes one by one. When it detects change in light sensor will memorize the code so if the light sensor is not properly connected 2 cases might happen:
1. it might stop the unlock process before finding the correc code (usually if the external light influences the light sensor).
2. it might not stop the process until the user takes out the sensor or changes the screen. (usually if it's not properly connected - between icons). Usually this happens if the screen brightness is very low (Use V.23 will auto adjustment).
LED blinks/activates when:
  • Blinking per few second when a code is sent to phone (while MFC is connected to phone);
  • Fast blinking when the unlock process is done (while MFC is connected to phone);
  • Stay ON completely when you connect to computer and the CAPS lock key is ON in the computer (while MFC is connected to computer)
About the sensor testing ?
To see if the sensor is working just press sensor checkbox On the MFC Software and watch if the sensor values change. If you put the sensor in dark/black & White place ( for example holding in your hand (Or Phone Lock Screen dark area), the value must be lower or 0 and if you put the sensor direct towards a powerful light (White screen or Emergency screen)the value must be higher 100 to 500. This is how you can test the sensor easily.
Where to put the sensor ?
  • Old sensor detected value is 0 (10k ohm Chip resistor, marked 1001)
  • New sensor detected value is 20 (20k ohm Chip resistor marked 2001) - To work more stable , We recommend All the Users change to this new sensor
IOS 7 with Darkness Area, IOS 8 With Lightness Area
The Following 3 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 02-05-2015, 16:30   #8 (permalink)
Member: 79315
Thanks Meter: 4,700
unlock IOS8.x passcode by MFC
About IOS8.x passcode unlock ?
  • iOS 8.0 、 8.0.1 8.0.2 8.1 support by Version 1.1.6.
How is work for this new version:
  1. Open device and disconnect the battery and input related iPower VCC connector to the battery socket, then connect phone battery to the iPower VCC connector.
  2. Connect external power to iPower adaptor. (can be max 5V2A good quality charger, minimum 1A power. you can also use 4v from a good power supply). We have tested using 5v while unlocking iPhone 4s and iPhone 5. but if you have a bad quality charger that will supply more than 5v we recommend you to use an 4v external power.
  3. Connect the light sensor to iPower adaptor white socket and put on the Phone (usually at a corner of the phone screen where no messages are displayed during boot procedure. Also avoid the middle of the screen as it will display the light increase icon and this can stop the unlocking prematurely).
  4. Connect the USB 3 in 1 charging USB cable to iPower adaptor USB slot
  5. Connect the USB 3 in 1 charging USB cable related connector to phone
  6. Programm the MFC with the appropriate code settings (Delay time is not relevant for this update as the timing is already automatic)
  7. Insert MFC Dongle into the iPower Adaptor.
  8. Insert micro usb cable charger to iPower adaptor(can be max 5V 2A good quality charger), Now the MFC LEDs will start blinking and the phone will power up automaticlly, Then connect MFC Dongle to 3 in 1 USB cable OTG port. Please do not connect MFC Dongle before any above steps as the unlocking process might not start correctly.
Upgrading to new Versions:
  • We encourage all customers to upgrade to this latest version 1.1.6. The downloaded version of the software is available now, You can using the MFCDL Tools V2.0 to upgrading to latest version. Here you can Download SN Reader.
About iOS 8.0.x - 8.1 Auto Mode V1
What we needed?
  • MFC Dongle
  • iPower Adaptor
  • 3 in 1 OTG Charging USB Cable
This update will try one code after each phone will restart. The restart is performed automatically using the iPower adaptor by MFC Box Team. Please read full details from instruction and check support forum before you do unlock your device.
The reboot time depends on the phone (newer models reboot faster). Usually is about 40 seconds(E.g.iPhone 5). Maximum time is 4.6 days in this way from 0 to 9999(111 hours).
In case your phone displays Phone disabled 15 minutes remaining, you will have to wait at least 15 minutes before starting to unlock. Codes sent to the phone during this time will always be invalid even if the code is correct.
If phone displays 23 million minutes remaining it means the phone has lost correct time setting after taken out the battery. You can insert an active simcard into the phone to get the correct time and date then revert back to the normal 1,2,15,60 minutes waiting message etc. In our test we were able to use MFC even without simcard as the phone will revert back to the normal waiting time after the first reboot.
To input the Sim only allow the active sim, and the sim not active internet function. Due if you input the SIM if with internet function activatied this maybe case Phone erasing. (which happened the phone active erase by icloud.)
But you need to take into consideration the fact that if the phone displays wait for 60 minutes then have to wait 60 minutes until you can really start to unlock procedure.
Once the code is found the phone will be automatically powered off and MFC Dongle stop sending codes. We had to do this to prevent phone going to permanently Disabled mode if the code found is not correct one. To be sure we got the right code you can unplug MFC Dongle from iPower adaptor (read the code using the computer if you wish) and plug back again into iPower adaptor to checking. If this time MFC Dongle stops again then you can be sure the code is the correct one. ATTENTION ! Do not move the light sensor from the previous position. Also it is reccomended to use tape to tape the sensor to phone. Because phone vibrates after every code,the sensor position can change and the unlocking might get fail.
Well, it seems complicated but actually it's the best and safe solution for this moment ! so we are recommend you doing some testing on working phone before you try to unlock the customer's device !
iOS 8.0-8.1 Auto Mode V2
NEW ! V2 Auto Mode contains some improvements over V1:
You can use delay to setup the time to wait until the first code is sent to the phone. for this update the delay must be input as seconds not miliseconds. So please input 16 for 16 seconds, not 16000 like for previous updates, this is required because the previous updates did not required delays greather than 60 seconds (60000).
In the case of iOS 8 is possible you might have to wait first the phone to aquire signal in order to get the correct Time/Date from network and exit the phone disabled mode. or just wait for the Phone disabled (x minutes) until you can try the first code. While phone displays Phone Disabled message any code MFC dongle might try is lost because it will not work even if it is the correct code.
About Alphabet function :
0123456789 is default meaning all digits will be used.
E.G.
Only want to try digits 6,7,8,9 , then put here FFFFFFF6789
If 0F23456789, then means 1 will not be tried in all codes. (Update On server 2015-4-20)
About Unlock Code for IOS8 V2 :
Every time phone reboot will be show the input code on phone screen.
And once phone unlocked, Phone will be shut down first, then auto reboot , the same time will be input same code to double confirm the last code is correct, and phone screen will be keeping like this image until you do next operation.
E.G. The 1234 is the unlock code.
Old 02-09-2015, 08:44   #9 (permalink)
Member: 79315
Thanks Meter: 4,700
iPower Adaptor user manaul V1 -2015-02-09
Old 02-15-2015, 03:36   #10 (permalink)
Member: 79315
Thanks Meter: 4,700
Connections for IOS 8
Old 03-14-2015, 09:47   #11 (permalink)
Member: 79315
Thanks Meter: 4,700
Arrow MFC Dongle Initial Setup Full Instructions (2015-02-15 ios 8 V2) ★★★★★
iOS8.0 -8.1 New Test Point For "iOS 8.0-8.1 Auto V5"
How to ?
We need Connect this TP (Test Ponit) to iPower Adaptor Boot PIN P0.
Old 03-14-2015, 09:49   #12 (permalink)
Member: 79315
Thanks Meter: 4,700
iPhone 6 / 6 Plus Test Point
Old 03-14-2015, 10:15   #13 (permalink)
Member: 79315
Thanks Meter: 4,700
iPhone 5s Test Point
Old 03-14-2015, 10:31   #14 (permalink)
Member: 79315
Thanks Meter: 4,700
iPhone 5/5c Test Point
Old 03-14-2015, 19:23   #15 (permalink)
Member: 79315
Thanks Meter: 4,700
About the Test Ponit ?
To Smart Master,
This solution should be working for iPhone 4S / iPod Touch 5 / iPad Air / iPad mini Retina ( iPad mini2 ) / iPad 4 / iPad Mini / iPad 3/ iPad2 .
As we can see , i only list TP for iPhone 6 / 6 Plus and iPhone 5 5c 5s at here, So please help us, if you can do something for this.
(To help us, you will be coming our Beta version tester)
But almost the TP are same position, Hope when you working on other models, Take some pictures to Sharing here.
How to find the TP ?
A. Power on your Device
B. Using multimeter "+" "-" , Touch one of the multimeter "-" probes (Black color) to Phone GND. Using "+" probes (Red Color) to touch the Home Button flex cable connectors pins or home button rearface welding spot. Once you saw the Device Screen start to Changing or Device Voice Control actived. Congratulations ! That's the Test Ponit we need to use.
Once you found , Please send related good pictures to [email protected]
Thanks!
MFC TEAM
Page generated in 1.06828 seconds with 8 queries
