01-27-2015, 09:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | MFC not entering normal mode (Fixed) [info] This update adds new functionality to your MFC Dongle. Now code is saved even if the phone closes because battery is too low or if you take out MFC Dongle from the OTG adaptor by mistake. [info] connecting... [data] > Device has firmware version 2.1 [data] > Serial number: 0x83AD8xxx [erro] Failed to load update from update server! i''ve tryed to repair with MFC_REPV3 [info] > Program started! Please input first your serial number as it appears on the serial number sticker! [sett] Please input a correct sticker serial number! [sett] Using sticker SN 0x83AD8xxx Please connect MFC Dongle in BOOT MODE to continue... [info] Current SN: 0x83AD8xxx FW: 2.1 [warn] Serial number matches the sticker ! [info] Current SN: 0x00000000 FW: 2.1 [warn] The sticker SN and the Current SN does not match! Checking ... [done] You allready have the latest firmware version! [info] Current SN: 0x83AD8xxx FW: 2.1 [warn] Serial number matches the sticker ! ANY SOLUTION ??? Last edited by .::Gsmdenis::.; 01-27-2015 at 10:44. Reason: sn edited |
