Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 01-27-2015, 09:27   #1 (permalink)
IM8
Member: 694535
Thanks Meter: 70
MFC not entering normal mode (Fixed)
MFC not entering normal mode after tryng range 6985-9999..... in mfc software only BOOT MODE when try to update :
[info] This update adds new functionality to your MFC Dongle.
Now code is saved even if the phone closes because battery is too low or
if you take out MFC Dongle from the OTG adaptor by mistake.
[info] connecting...
[data] > Device has firmware version 2.1
[data] > Serial number: 0x83AD8xxx
[erro] Failed to load update from update server!
i''ve tryed to repair with MFC_REPV3
[info] > Program started!
Please input first your serial number as it appears on the serial number sticker!
[sett] Please input a correct sticker serial number!
[sett] Using sticker SN 0x83AD8xxx
Please connect MFC Dongle in BOOT MODE to continue...
[info] Current SN: 0x83AD8xxx FW: 2.1
[warn] Serial number matches the sticker !
[info] Current SN: 0x00000000 FW: 2.1
[warn] The sticker SN and the Current SN does not match! Checking ...
[done] You allready have the latest firmware version!
ANY SOLUTION ???
Old 01-27-2015, 10:45   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Repairing dongle must be put in the boot mode
Old 01-27-2015, 10:47   #3 (permalink)
IM8
Member: 694535
Thanks Meter: 70
it is in boot mod gnd and p0
Old 01-27-2015, 17:21   #4 (permalink)
IM8
Member: 694535
Thanks Meter: 70
still no answer .......
Old 01-27-2015, 18:47   #5 (permalink)
Member: 79315
Thanks Meter: 6,024
Check your MFC Dongle if have some shortcut
Old 01-27-2015, 18:54   #6 (permalink)
IM8
Member: 694535
Thanks Meter: 70
What do you mean by shortcut ? details or answer skype
Old 01-27-2015, 18:55   #7 (permalink)
Member: 79315
Thanks Meter: 6,024
mean's have A short circuit
Old 01-27-2015, 19:13   #8 (permalink)
IM8
Member: 694535
Thanks Meter: 70
NO Short circuit..... in boot mode he seen the serial nr. but it doesn't enter in normal mode ... in device manager it shows "input device "with "!"
Old 01-27-2015, 19:20   #9 (permalink)
IM8
Member: 694535
Thanks Meter: 70
this problem appear after unlocking 2 pcs and tryng to unlock the 3rd lat time mfc was connected to win 7 64bit
Old 01-27-2015, 20:03   #10 (permalink)
Member: 79315
Thanks Meter: 6,024
Try it on another computer or different USB port. your dongle as i checked on server with new firmware , should be without problem
Old 01-27-2015, 20:35   #11 (permalink)
IM8
Member: 694535
Thanks Meter: 70
Tryed on 2 different comp. one with win 7 32bit The Other one win 7 64bit also different usb
Old 01-27-2015, 20:54   #12 (permalink)
Member: 79315
Thanks Meter: 6,024
Could you take some clear picture for the dongle and your connections ?
Old 01-27-2015, 21:16   #13 (permalink)
IM8
Member: 694535
Thanks Meter: 70
Can i give u teamviewer id and pass in pm ??
Old 01-28-2015, 13:51   #14 (permalink)
IM8
Member: 694535
Thanks Meter: 70
problem solved after u very the SN dongle working on any pc
Old 02-11-2015, 19:45   #15 (permalink)
IM8
Member: 694535
Thanks Meter: 70
Problem came back
Same problem again we need a fix
Page generated in 0.19102 seconds with 8 queries
