Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 09-25-2017, 07:34   #1 (permalink)
Member: 2120342
Thanks Meter: 25
My box is not open
PLZ HELP
[info] Loading history ...
[erro] Cannot login to server without a valid SerialNumber. Please read the serial number using management tab!
[info] > Entering boot mode ...
[erro] > Error reading firmware version !
ERROR CAME
NOT CONNECTED
Old 09-25-2017, 08:51   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Go to "MFC TOOLS" Tab read serial number , thanks
Old 09-25-2017, 10:35   #3 (permalink)
Member: 2120342
Thanks Meter: 25
i am checked 2.1 setup is working
but 2.2 setup is not working
Old 09-26-2017, 07:07   #4 (permalink)
Member: 79315
Thanks Meter: 6,024
before install 2.2 , you have to uninstall all the old version , thanks
Old 09-26-2017, 10:50   #5 (permalink)
Member: 2120342
Thanks Meter: 25
also same problem. and i am installed in other PC also same error
2.1 only works
Old 09-26-2017, 20:20   #6 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
check device manager, is drivers install correctly?
Old 09-27-2017, 12:02   #7 (permalink)
Member: 79315
Thanks Meter: 6,024
2.1 only works
Error reading firmware version ! that's becoz of usb port issue,
V2.2 was completed reconstruct code, so don't put 2.1 and 2.2 in same folder. just need readout the serial number then will be work for sure.
Old 09-28-2017, 10:57   #8 (permalink)
Member: 2120342
Thanks Meter: 25
Ok thanks problem solved
Old 09-28-2017, 18:14   #9 (permalink)
Member: 79315
Thanks Meter: 6,024
That's good to know your problem fixed, enjoy ur time
BR.,
Old 11-11-2017, 00:49   #10 (permalink)
Member: 2169629
Thanks Meter: 6
i have same error, need link v2.1
Old 11-11-2017, 15:41   #11 (permalink)
Member: 79315
Thanks Meter: 6,024
Can you let me know what's problem ?
Page generated in 0.22980 seconds with 9 queries
