01-04-2016, 00:08 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2331572 Status: Offline Sonork: 1662015 Thanks Meter: 2 | Need help! Not working Test Point (iPhone 4S / iPhone 5 / iPhone 5S) When you connect Test Point, the phone does not reboot. Why? What am I doing wrong? In the 4S was password dialog - I soldered a wire to the TestPoint - Clicks plume of battery - Then pressed the Power button Phone is switched on and the display appears iPhone is disabled try again in 1,445 minutes Why did this happen after the soldered wire to TestPoint? What to do? * I shot a video * Several photos |
01-04-2016, 06:35 | #3 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | iOS 8 did not support to remove disable "Phone disabled connect itunes" but support "Phone is disabled try again in x mins"(This you have to waiting the time back to normally condition). So your iPhone 5s and 4s will be support using Test Point Method. thanks Br., Denis |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
01-04-2016, 10:12 | #5 (permalink) | |
Member: 2331572 Status: Offline Sonork: 1662015 Thanks Meter: 2 | Quote:
I know it. Thank you! But why did this happen? On the 5S will have a month to wait ( | |
01-04-2016, 12:31 | #7 (permalink) | ||
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Check this (So don't disconnect battery) : http://forum.gsmhosting.com/vbb/f936...8-1-a-1956984/ Quote:
You can using some frame like this to holding the power button: Metal bumper frame customize tool 4 in 1 set | MFC Dongle | ||
