02-13-2016, 17:13 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2331572 Status: Offline Sonork: 1662015 Thanks Meter: 2 | Need help! With Test Point (iPhone 4S / iPhone 5 / iPhone 5S) but it was closed ( I bought a metal bumper and decided to continue with Test Point. Bumper their work makes, the phone restarts, this all is well! But after the first reboot, the screen shows iPhone is disabled connect to itunes firmware iOS 8.0-8.1 Auto V6 phone connect 4S (iOS 8.1) Why is it written "iPhone is disabled connect to itunes"? For the selection of the code must be active first five attempts at entering the code? It works this method if I used the first five attempts at entering the code? Thank you! |
The Following User Says Thank You to jakaldenis For This Useful Post: |
02-14-2016, 00:49 | #2 (permalink) | ||
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Yes, if customer did not reply the topic will be closed. Quote:
i am not sure what you talking about this , maybe you can explian more | ||
02-14-2016, 09:57 | #4 (permalink) |
Member: 2331572 Status: Offline Sonork: 1662015 Thanks Meter: 2 | In the morning, the MFC Dongle stopped to pick up the code I put Dongle into the PC and saw it Code: [user][info] > Reading ... [user][data] > FWVersion is 33 [user][done] > Latest guess was 0581 format FFFF settings 02 delay 0 [user][sett] Extra area: 00 01 02 03 04 05 06 07 08 09 01 FF FF FF FF FF [user][sett] Turbo Mode: 1 - Auto [user][sett] > settings 02 format FFFF delay 30ms [user][sett] > Latest Guess at index 53 = 0581 [user][data] > (000,0000) (001,0000) (007,0000) (010,0000) (011,0000) (012,0000) [user][data] > (013,0000) (014,0000) (015,0000) (016,0000) (017,0000) (018,0006) [user][data] > (019,2720) (020,2650) (026,0000) (037,0000) (038,0000) (039,0000) [user][data] > (040,0000) (041,0000) (042,0000) (043,0000) (044,0001) (045,0000) [user][data] > (046,0000) (047,0003) (048,0000) (049,0000) (050,0001) (051,0000) [user][data] > (052,0000) (053,0581) [user][done] OK But when I entered 0581, iPhone wrote "iPhone is disabled connect to itunes" Why did it happen? MFC Dongle, picked the wrong code? |
02-14-2016, 13:46 | #6 (permalink) | |
For iOS 8 , the unlock code will show you on phone screen. Please read manual carefully and start from this page : Manual | MFC Dongle | |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
02-14-2016, 17:51 | #7 (permalink) | |
Member: 2331572 Status: Offline Sonork: 1662015 Thanks Meter: 2 | Quote:
********** And which version should I use? - IOS 8.0-8.1 Auto V6 - IOS 8.0-8.1 Auto V7 I have a 5S with iOS 8.0 and would like to pick up the code successful. Thank you! | |
02-14-2016, 19:38 | #8 (permalink) | |
If code did not show up, you may test your cable using this way: Manual | MFC Dongle IOS 8.0-8.1 Auto V7: Manual | MFC Dongle If you have any other problem , you can make some video and we can check for you ! | |
02-15-2016, 00:08 | #9 (permalink) | |
And i have a question: - I soldered a cable to the Test Point, when connected to MFC Dongle, flex cable must be connected to the motherboard or not? Thank you for your response to my question!) | |
