11-14-2022, 17:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: could'nt found yet
Member: 223973 Status: Offline Thanks Meter: 155 | unable to program for EFI Code: EFI Boot Mode v2 This is an improved variant of EFI Boot Mode update that is more reliable in detecting if the code was accepted\r Using this method code recovery time is maximum 33 hours for all 9999 possible codes(1 codes each 12 seconds) How to: - update MFC using EFI Boot Mode - write the appropriate settings using the software (the delay in milliseconds is 12000 for EFI Boot Mode) 12 seconds / code, older computers will accept code to be input faster, thus the delay can be adjusted for a lower value, you can check this by trying to input by hand codes and see how long time passes until the code you input is accepted by the computer. - connect the light sensor to the computer on the LOCK ICON displayed on the screen. - once unlocking is done the MFC will start blinking - you can read now the dongle using EFI Online Update software and you will see the latest used code. Searching MFC ... > Reading ... > FWVersion is 23 > Latest guess was 0000 format FFFF settings 00 delay 500 > settings 00 format FFFF delay 5000ms > Latest Guess at index 2 = 1234 > (000,0000) (001,1234) (002,1234) OK Last edited by kamiran; 11-14-2022 at 17:59. |
11-14-2022, 19:10 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Check this https://www.mfcbox.com/manual/#features/58 |
11-17-2022, 09:50 | #7 (permalink) |
Member: 223973 Status: Offline Thanks Meter: 155 | MFC Dongle 1. IMFC Customer 2. iBUS S2 Customer Activated List 1. July 03, 2023 06:58 PM 2. November 28, 2024 12:11 AM Valid Until what does that mean Your account was expired, Related permissions no longer valid until you renew it again. |
