06-18-2017, 23:18 | #1 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | 2 issues with IP BOX 6.1v Help 1- when plug-in to usb port IP-Box not detected, I need to go into systems and force to scan for new hardware, it was not like that with 5.2 2- I'm getting read error with every single Nand that was ok before, pick included. Any help will be apressiated. Thanks |
06-19-2017, 07:31 | #2 (permalink) |
Insane Poster Join Date: Jun 2008 Location: UK-PL
Member: 796570 Status: Offline Thanks Meter: 26 | Drivers issue ? I have win7 32bit pro and no problems with this kind of malfunction ... also riff and z3x is used at this same PC unit ! Unplug box ... than try use some recommended registry cleaner ! After restarting OS try install drivers again ... also can try reflash box firmware again or downgrade to lower version ! Updating framenetwork may not involved but recommended to keep up to date |
06-21-2017, 07:18 | #3 (permalink) | |
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
Thanks. | |
