07-25-2016, 20:00 | #1 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | ★★★ [ ABOUT ] Description of IPBox V2 - High Speed Programmer ★★★ Regard, .:: ARD ::. |
The Following 13 Users Say Thank You to .::ARD::. For This Useful Post: |
08-04-2016, 08:06 | #2 (permalink) | ||
Freak Poster Join Date: Oct 2014 Location: inside
Member: 2282325 Status: Offline Thanks Meter: 282 | IP-Box 2 IP-Box 2 is a high speed programmer for repairing / programming / reading / upgrading iPhone and iPad IC Chips. For Advanced users, The IP-Box 2 requires you to be proficient in IC chip removal from the iPhone / iPad logic board. Once removed you can read / write / repair the IC chip using IP-BOX 2 IC reader hardware and Software. IPBOX Features Quote:
IP-BOX 2 Software Platform Explained (1) IP_BOX 2 hard disk expansion, hard disk repair, hard disk test (the original hard disk can be used to extract information, write the new hard disk information, repair partition information, etc.) (2) NAND_Flash Apple hard disk for read, write, erase, write function blocks, etc. (3) SPI_Flash Suitable for Apples baseband chip to read, write, erase and other functions. support thousands of models SPI font. Suitable for iPhone 4s, iPhone 5, iPhone 5C , iPhone 5s , etc. (4) EEPROM for Apple eeprom read, write, erase, etc. Applicable models including iPhone 6, iPhone 6Plus, iPhone 6s , iPhone 6s Plus, iPhone 5se etc. (5) Firmware Upgrade Firmware Update to update the instrument firmware. IP-BOX 2 Expansion, hard disk repair Features (1) Aircraft options Depending on the phone model you want to modify. select the appropriate model (2) cell phone information hard disk data extraction. the device will automatically recognize the hard disk information and fill. Users can also manually enter the appropriate parameters according to the information they need (3) Hard Disk Data extraction extract the original hard drive data, it can reduce the step corresponding user input. more convenient (4) Operating parameters Quote:
IP-BOX 2 NAND_Flash Apple hard disk read, write, erase, write function block (1) Function buttons Detection ID hard to read ID, type, capacity and other information Reading Test Print out the internal part of the font data Reading all Read the full font data and save it to your computer Erase block According NAND start address. erase its corresponding block data Full Erase Empty the contents of the hard disk Write Block According NAND start address. writing data to the appropriate block Write all write full flash data Stop Interrupt button (2) NAND bus parameters NAND_Flash mode Depending on the font, you need to select a different mode NAND bus clock This is a read and write speed (3) read test, block erase, write block option NAND page start address NAND_Flash_ chip select Apple hard disk has a plurality of chip select, such as CE1 / CE2 / CE3 / CE4 (4) To read font, write library, erasing all options Default. no user operation. if cancelled hook will result in failure to read font. 3. SPI_Flash (baseband chip to read, write, erase, repair) (1) Options Detection ID read chips (font) ID, type, capacity and other information Reading Test Print out the internal part of the font data Reading all Read the full font data and save it to your computer Write all write full flash data to the chip Chip Erase Erase character content Compare Compare match inside information and font Stop Interrupt button (2) Setting Options Chip set various parameters, set automatic operation check on it (3) file to read, write path IP-BOX EEPROM for Apple eeprom read, write, erase and etc (1) Options Reading Test Print out the internal part of the font data Reading chip Read Full font data and save it to your computer Write chip data to write full flash chip Compare Compare match inside information and font Stop Interrupt button (2) Setting Options EEPROM Voltage Depending on the type of chip, select the appropriate voltage. 3.3V to the default Apple Clock (SLC) Depending on the type of chip, select the appropriate clock. Apple to default SLC 100KHZ (3) Chip Model Apple generally uses a CAT24C08C4A software defaults Beginning and ending addresses according to the chip model, the software will automatically set user adjustable general default on File option read, write, file path BR, IPBOX V2 TEAM | ||
The Following 10 Users Say Thank You to iPbox For This Useful Post: |
