06-06-2017, 12:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | activation problem after rewrite after erasing nand i rewrote all info. after that i checked using 'extraction disk data' that time all info ok. after re insert updating full done but activation error. again i remove nand and checked using ip box but,,, that time shows all info erased then rewrite all info and re inserted to the phone , then phone full working (not update need that time) i face this problem iphone 5s, 6, 6plus why it need againg write info? it is very difficult to remove nand many times from pcb give me solution |
The Following User Says Thank You to Abussabah For This Useful Post: |
06-09-2017, 14:33 | #2 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
buy the nand testfixture so you dont need to remove the nand again and again thats the reason why IPbox put the fix invalid SN botton on software | |
06-09-2017, 15:37 | #3 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: Canada
Member: 1773784 Status: Offline Thanks Meter: 27 | Quote:
06-21-2017, 11:30 | #4 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
What I think is that IP Box 2 don't know how to write the boot area of the Nand corretly, once iTunes finds the new nand it thinks something happen and restores the boot part of the nand and that erase the Nand and serial because it was on the wrong place, but once you put it back and IP Box 2 read it it now knows where it should be and writes it back. More and more issues are happening with the new phone/ipad and I don't think the makes of IP Box are spending anytime to fix it since new phones/ipads will use different pcie interface complicating things even more (for now) | |
06-22-2017, 07:59 | #5 (permalink) | |
the box has no problem, put on your mind the IOS is very high security and until now no one could ever decode it every IOS update security is high and the process to fix it is not like before as you think,, i know what you ment to be but if you notice IPBOX put the button FIX INVALID SN on the software why you didnot use that botton to solve your problem i posted here many times the guide, you only have to do is just look for it and apply to your self and dont blame the box dont know how to write boot file | |
06-24-2017, 03:40 | #6 (permalink) | |
I offered an explenation why... I do own the box and stuck with it until I find a good upgrade with PCIE, the box works well will the old devices, but poor with the new that it. Not been able to do a single ipad air 2, my only option now is buying 5 pices lots from china. (brand new, not the used crap sold on some sites) I do like the box and I think I might have an idea of who designed and developed the software, I found the design on the net and they are not chinise. BTW: pcie version is already in production acording to what I found. | |
06-24-2017, 05:46 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | https://www.aliexpress.com/item/3pcs...208.4.8.VI7Noq yes this will avoid too much heat again and again to the pcb as well as to the nand also this make the reprogramming process easy and save time with ip box. One thing make sure you test the connectivity with a multi meter otherwise there are some bad flexes .. Last edited by gayansuranga; 06-24-2017 at 05:51. |
06-25-2017, 09:16 | #8 (permalink) | |
