12-12-2016, 22:45 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: Egypt Age: 33
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | Extract Data From Dead Iphone Can i use IP-BOx to extract data like photos from NADA Chip ? Can i read hole NADA data and save it for Forensics Purposes ? Ofcurse after Remove NADA chip from the board. |
The Following User Says Thank You to expenaticx For This Useful Post: |
12-13-2016, 01:18 | #3 (permalink) |
Freak Poster Join Date: May 2014 Location: Anywhere
Member: 2182001 Status: Offline Thanks Meter: 52 | Yes you cant extract user data are encrypt with sep key... Only if u can edit (need a very master on reverse) secure rom u can read data in other iphone same limera1n Inviato dal mio iPhone utilizzando Tapatalk |
06-26-2017, 00:09 | #4 (permalink) | |
Insane Poster Join Date: Jun 2008 Location: UK-PL
Member: 796570 Status: Offline Thanks Meter: 26 | Dead iPhone ? Transfer chips to another one Quote:
Main problem is the "data is saved by 256bit secure alghorytm" which (as far as I know) is stored in CPU .... long story short ... IC mentioned above are paired together can be moved as set to other motherboard ! Instead looking for shortcut better will be spend this time to learn about programming language ... I guess it could be more profitable than asking at forum and counting at someones "mercy" to explain whole procedure ! I post this coz wish to save your time ! At the moment that forum is one of trustfull which I know and try to keep info up to date to create professional enviroment coz mostly You can receive simple answers like "yes...no... use search button" | |
The Following 3 Users Say Thank You to Maison3k For This Useful Post: |
07-10-2017, 06:01 | #5 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
The only way is to fix the iphone, I'm not sure if just by transferring all the other parts will do it since so far on any data recovery I seen in UT every body try to bring back original phone. BUT if I'm reading your question correctly you are not trying to read your own data, remember once you bring back the Nand to another phone it will bootup with the content of the Nand and if password protected then you'll have to find a way to bypass that too. Good luck BTW: Apple pays good money for things like the one you are asking for and if you find out how they will give you money, and this is not a trick is true you can ask around if you like or search the internet. | |
07-12-2017, 01:22 | #6 (permalink) | |
Freak Poster Join Date: Jan 2013
Member: 1872250 Status: Offline Thanks Meter: 33 | Quote:
of course after 20attempts the counter will be disabled,but you can take nand mirroring and restore the nand backup after iphone disabled the forenics team use this method for 6digits passcode ,it takes about 40days | |
07-17-2017, 05:30 | #7 (permalink) | |
That is the only part missing from their virtual emulator. Encryption is all the same the only thing that changes is the key and you have that if you have the physical hardware. Once you have that loading a bit by bit backup of a Nand should not be a problem. good luck. | |
12-14-2017, 12:15 | #8 (permalink) |
Insane Poster Join Date: Sep 2013
Member: 2018487 Status: Offline Thanks Meter: 2 | so i have a customer who wants a data recovery on her iphone 6.. iphone is badly smashed to extent that the motherboard snap into 3 pcs (i dont how she done it).. she badly needs all her stuff on her phone for apparently "court trial purposes". is there anyway i can get the data off? she's willing to pay $$$$$.. |
