04-17-2017, 13:27 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | if you dont know do not miss lead the other member, ipad gsm is not like ipad wifi @Albo221 you can bypass icloud for ipad gsm using jumper, and restore it to ipad wifi, but the sim will not work anymore not unless you remove jumper and restore to GSM then the sim will work, but the icloud will be remain if you want to remove the ipad with sim has working use server to remove it but so expensive use search button how to bypass gsm ipad already posted here on forum |
The Following User Says Thank You to maxieboy For This Useful Post: |
