Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > IP-BOX (The SMART Tool)
Old 02-15-2017, 11:30   #1 (permalink)
Member: 2383669
Thanks Meter: 10
Help With IP BOX
Hello
i have ip box v2
i have ipad 4 icloud locked i back up all details and format and write the info with little edit with s/n but now give me error 40 or 9 or stuck on wait for ipad
how to use this box with all iphone and ipad ?
Any one have general sloution ?
THANX !
Old 02-15-2017, 11:41   #2 (permalink)
Crazy Poster
Member: 1527883
Sonork: 100.1637238
Thanks Meter: 23
Not properly soldered the NAND IC.
Old 02-15-2017, 13:41   #3 (permalink)
Member: 2383669
Thanks Meter: 10
i resolder it many times diffrrent boot files and another emmc from iphone 5 but same
Old 02-15-2017, 13:55   #4 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
flash the ipad without lcd and post result
Old 02-16-2017, 06:16   #5 (permalink)
Crazy Poster
Member: 1527883
Sonork: 100.1637238
Thanks Meter: 23
After changing the serial of NAND IC did you read it again before soldering it to the ipad board?
Old 02-19-2017, 05:40   #6 (permalink)
Member: 2685790
Thanks Meter: 21
Did anyone find out how to fix this issue?
I have two iPhone 6 with error 40. I tried a bunch of other nands having same issue.
I've flashed it with ip box. Changed Sn but still having issues.
I've copied boot 1 & 2 over and just changed sn still having issue.
iTunes log file says " no nand detected."
Old 03-16-2017, 13:25   #7 (permalink)
Member: 1528845
Thanks Meter: 6
..did you remove the underfilling under the nand and from the board?
Old 03-16-2017, 13:53   #8 (permalink)
Member: 1803458
Thanks Meter: 8
Hello
i have ip box v2
THANX !
You can just put iphone 5 nand without any operation on ip box and it should flash without any error. Then you can edit sn with ip/
But if same 40, than you need check nand pins on PCB
Old 03-17-2017, 08:29   #9 (permalink)
Member: 2171747
Thanks Meter: 10
The problem is that he formatted the nand you should have not, since is not required to do so to change the serial! All you had to do was press extract on the boot area then change the serial, press write, solder nand back and voila! Now the way you will fix it is by choosing the boot files ip box provides for the nand you have rewrite the serial and figure out the wifi and Bluetooth address write it, solder back and that will solve the issue ! Now if you skip writing the wifi and Bluetooth address you won't be able to activate iPad even with iTunes
Sent from my iPhone using Tapatalk Pro
Old 03-23-2017, 09:26   #10 (permalink)
Member: 1528845
Thanks Meter: 6
Hello,
yesterday my ip box 2 arrived from singapur. can you help giving me advice for programming a iphone 6 nand?
i want to upgrade old 16gb to new 128gb nand.
i could read the data of the 16gb nand in the menue "IP_BOX2" with slecting "iphone 6" and clicking on "Disk Test". This worked fine! What is the next step? I put the 128 gb nand in the programmer and have to click only on "write"? is there something else to do? for what is the boot1 and boot2 field? thanks for help
Old 03-26-2017, 06:06   #11 (permalink)
Member: 2171747
Thanks Meter: 10
Select iPhone 6, put the 16gb in the box, hit disk test, on the boot area hit extract and once extracting is done take the 16gb out insert the 128gb hit write! Wait for it to finish and voila put the 128gb to iPhone 6 board restore. That's it you'll have 128gb iPhone 6
The Following User Says Thank You to magdani For This Useful Post:
Old 03-28-2017, 06:25   #12 (permalink)
Member: 1528845
Thanks Meter: 6
Hell Magdani,
thanks for this helpfull reply. I changed the serial number first and after that i wrote it back to the nand. I modified my first iphone 6 and it works! Great!!
What´s about "Error 4013" ? I think it is the same, but i have to erase the nand first and then write?
The Following User Says Thank You to tester2011 For This Useful Post:
Old 03-28-2017, 11:34   #13 (permalink)
Member: 1939450
Thanks Meter: 165
Originally Posted by tester2011 View Post
Hell Magdani,
I am not 100% sure if it was error 4013 or 4014 but i solved some with putting an external power on the ipad. (the ipad had just not enough energy in the battery)
Old 03-28-2017, 21:45   #14 (permalink)
Member: 2685790
Thanks Meter: 21
I was told error 4014 is nand issue
Nand Not connected. I was told to reball.
But I bought a ribbon cable for the nand and I just soldered the pins
Of nand to ribbon cable and the other side I soldered to iPhone and
Fixed one iPhone 6 that was error 4014.
But the other iPhone 6 I have has error 4014 just hangs in dfu. It doesn't switch
Over into recovery when restored with iTunes or 3utools.
I think this one might be power issue. I've tried 3 different batteries but still error 4014. I'm going to take off nand. Add ribbon cable and see if it solves this one.
Old 03-29-2017, 15:53   #15 (permalink)
Member: 2700216
excuse me! I haven't understood at all that write at this forum. prompt where it is necessary to come at a forum? where grant of IP-BOX2 the rights at a forum?
Page generated in 0.20632 seconds with 8 queries
