11-07-2016, 17:27 | #1 (permalink) |
Junior Member Join Date: May 2015
Member: 2391208 Status: Offline Thanks Meter: 1 | Help... iP-Box v2 Disk Test Error WARNING... CE2 Chip select, please check Nand ID2 & Nand Extend... can help me??? i try a 2 PC, but same... i use Ver_4.0_EN & VER3.9C_en, but still same |
11-07-2016, 23:19 | #3 (permalink) | |
Freak Poster Join Date: Jan 2011
Member: 1505548 Status: Offline Thanks Meter: 24 | Quote:
can post log test another ipbox2 (your's friend) maybe brother Thank you very much | |
11-07-2016, 23:23 | #4 (permalink) | |
http://forum.gsmhosting.com/vbb/11988249-post2.html here is support list http://forum.gsmhosting.com/vbb/12002937-post8.html | |
11-08-2016, 04:03 | #6 (permalink) | |
Member: 2391208 Status: Offline Thanks Meter: 1 | Quote:
11-12-2016, 09:47 | #11 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | then you can do this process - erase all - extract boot file - write SN, bluetooth,wifi, (ORIGINAL DETAILS OF PHONE) - write - done Last edited by maxieboy; 11-12-2016 at 09:53. |
11-12-2016, 16:33 | #13 (permalink) |
Freak Poster Join Date: May 2014 Location: Anywhere
Member: 2182001 Status: Offline Thanks Meter: 52 | I think u need read boot config for each nand, after you need erase all (nand tab) after rebuild all cfg by system 64 folder.. Ps check connection in socket i think.. Inviato dal mio iPhone utilizzando Tapatalk |
