12-09-2016, 13:15 | #20 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | So fare i can see user ''zhulianqi'' post the software update. I will send him a PM in a minute to get his attentions. Hopefully they can solve this problem in an update or a clear tutorial. |
The Following User Says Thank You to timvandenboo For This Useful Post: |
12-12-2016, 00:32 | #25 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
no need to understand if you can't just watch this video https://www.youtube.com/watch?v=ouxDq3n6Tdg | |
12-13-2016, 15:34 | #30 (permalink) |
Freak Poster Join Date: May 2014 Location: Anywhere
Member: 2182001 Status: Offline Thanks Meter: 52 | For Solve Error 40 If you have a backup of your nand do this, Only for same nand! And no error in disk test! 1 Erase 2 Boot1 ->select user_read folder, Iphone6_Bot1_ce2xxxxx.bin 3 Boot 2 -> select user_read folder Iphone6_bot2_ce1xxxxx.bin 4 Flag only: create disk part and update info 5 Write Test If not done 1 remove nand 2 Reselect Boot1 / Boot2 same in the first method 3 Flag User to extract Boot1; Create disk partition ; Update new info 4 Write If not done remove and click fix sn tab (Fix ios 10 error 40= Ipbox >5.0) Ps. If you dont have backup of your data, you need to restore boot with file in system/64bit folder Last edited by genhack23; 12-13-2016 at 15:43. |
