Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > IP-BOX (The SMART Tool)
Old 09-22-2017, 12:51   #1 (permalink)
Member: 1514202
HELP! not installing drivers on windows 10 64
cant find anydrivers for win 10 64bit! drivers from instalations not supported from windows!!!((( HELP!!!
The Following User Says Thank You to ZerO-KiLLa For This Useful Post:
Old 09-22-2017, 15:02   #2 (permalink)
Member: 302596
Thanks Meter: 784
i think there is no driver for windows 10 64 bit, anyway try the old driver from window 7 64bit hope it will work
Old 09-22-2017, 15:38   #3 (permalink)
Member: 1514202
its not working(( i try((
Old 09-22-2017, 15:57   #4 (permalink)
Member: 302596
Thanks Meter: 784
have you try to install manually ? by adding it into you registry ? i cant assest you further because im window 7 64bit user
may be the developer need to update on windows 10 os
Old 09-25-2017, 12:55   #5 (permalink)
Member: 1514202
Dear ARD please add Windows 10 64bit drivers in programm!!!!!!!!!!
Old 09-25-2017, 13:07   #6 (permalink)
Member: 1675922
Thanks Meter: 61
Windows 7 64bits drivers will work on Win10 64 bits.
Tested by me.
You can't install because in Win10 driver signature enforcement is enabled by default.
But you can disable this check by following the steps from link:
https://www.howtogeek.com/167723/how...igned-drivers/
After disable, you will be able to install the drivers.
The Following 2 Users Say Thank You to mcmihai003 For This Useful Post:
Old 06-26-2021, 10:16   #7 (permalink)
Member: 2642070
Thanks Meter: 15
PS C: \ Windows \ system32> bcdedit / set testsigning on
An error occurred while setting item data.
The value is protected by Secure Boot Policy and cannot be changed or removed.
Page generated in 0.14028 seconds with 8 queries
