05-24-2019, 12:13 | #1 (permalink) |
Freak Poster Join Date: Jul 2011 Location: SUVA
Member: 1622774 Status: Offline Sonork: 34610 Thanks Meter: 37 | Inbox 2 change sn fail help. |
The Following User Says Thank You to cxl2156565 For This Useful Post: |
07-04-2019, 20:23 | #2 (permalink) |
Junior Member Join Date: Dec 2007
Member: 644828 Status: Offline Thanks Meter: 1 | ipad2 serial blank hi, when i did one of these and placed it on i tunes the serial only shows while its downloading the software then says n/a after that all the way through the install, once it has installed ok it should say congratulations on your new ipad etc etc, and give you all the details on the size of hdd the serial number and much more. If the data your saving at the start is correct and you have checked it over and over before you press write then check again in the left black window what its entered into the nand is same as what was on it to start with i see no problem there, as long as you have erased all the boot data that held the icloud info to start with you should be fine, Now im only going on my experiance that i did when i acheved a working ipad2 that had icloud lock on it, hope this gose some way to help you. |
The Following User Says Thank You to DOUG.COM For This Useful Post: |
07-04-2019, 20:31 | #3 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 495 | Problem is serial number is bad buy new SN BT WiFi mac then change not format step restore ipad Envoyé de mon iPhone en utilisant Tapatalk |
