09-01-2018, 07:49 | #1 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2790377 Status: Offline Thanks Meter: 2 | Ip box have no power Any have an idea how to fix the box ?? أرسلت بواسطة iPhone بإستخدام Tapatalk |
09-02-2018, 07:30 | #4 (permalink) |
No Life Poster Join Date: May 2012 Location: In Your Heart Age: 37
Member: 1759636 Status: Offline Sonork: 100.1591515 Thanks Meter: 785 | please give us pic that which one is your box many non registered Companies launch there fake boxes by name of IPBOX please clarify us to got good reply WBGSM |
09-02-2018, 15:13 | #6 (permalink) |
Member: 2790377 Status: Offline Thanks Meter: 2 | Ip box have no power [QUOTE=WBGSM;13296914]please give us pic that which one is your box many non registered Companies launch there fake boxes by name of IPBOX please clarify us to got good reply WBGSM[/ أرسلت بواسطة iPhone بإستخدام Tapatalk |
09-05-2018, 09:41 | #9 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Is this box with lightining connector or type micro-usb connection ? If it has usb type micro-usb connection then it is a possibility that you need to replace the connector or try resoldering it. It is very fragile and after heavy usage gets ripped off easily. My box too has similar issue ever other week. Hope that helps. |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
09-06-2018, 08:07 | #10 (permalink) | |
Member: 1759636 Status: Offline Sonork: 100.1591515 Thanks Meter: 785 | [QUOTE=garka;13297420] Quote:
contact with me 100.1591515 and from whom you buy this box? | |
09-06-2018, 12:14 | #11 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | I had to Solder the usb cable directly to the PCB. Cause all of the pads get stripped off. |
09-07-2018, 17:29 | #12 (permalink) |
Member: 2790377 Status: Offline Thanks Meter: 2 | [QUOTE=CDMA_RASHID;13304274]I had to Solder the usb cable directly to the PCB. Cause all of the pads get stripped off. Thanks for your reply i will check the connector أرسلت بواسطة iPhone بإستخدام Tapatalk |
09-12-2018, 06:48 | #13 (permalink) |
Member: 2790377 Status: Offline Thanks Meter: 2 | thanks u all , it's worked , after changing the cable and the pc software . even though i already have changed the cable once maybe it was a software problem , after all i have a question what the difference between ipbox2 and ipbox3 , how i can know mine 2 or 3 . thanks .. |
09-12-2018, 21:15 | #14 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | Your's is ipBox v2. The difference between v2 and v3 is that v2 support's the following devices. 32bit (iphone 4,4s,5) 64bit (iphone 5s,6,6+). Whereas IpBox v3 support's 32bit (iphone 4,4s,5). 64bit (iphone 5s,6,6+). As well as. PCIE devices such as (iphone SE,6s,6s+,7,7+) Hope this answers your query. |
The Following 3 Users Say Thank You to CDMA_RASHID For This Useful Post: |
09-12-2018, 22:15 | #15 (permalink) | |
Member: 2790377 Status: Offline Thanks Meter: 2 | Quote:
Thank u my friend أرسلت بواسطة iPhone بإستخدام Tapatalk | |
The Following User Says Thank You to garka For This Useful Post: |
