07-25-2018, 16:17 | #1 (permalink) |
Freak Poster Join Date: May 2010
Member: 1315082 Status: Offline Thanks Meter: 16 | IP BOX V2 ERROR OF Warning of CE2 CHIP Select nand id2 here is log... >>> Is reading Nand_Flash information... Nand_ID : 0x50504E010508 Nand_EXTEND_ID : 0xAD8260242102 Nand_Information: 054715P_HYX_CD16 >>> WARNING ... CE2 chip select, please check ... Nand_ID2 : 0x000000000000 Nand_EXTEND_ID2 : 0x000000000000 Nand_Factory : SKhunix Nand_Name : H2JTDG8UD1CMR Nand_PAGE : 256 Nand_PAGE_Size : 16448 Nand_ECC_Size : 64 Nand_CE_Number : 2 Nand_PLANE_Count: 2 Nand_Capacity : 17819631616Byte/16994MB/16.99GB >>> Operations are done... please solve assoon as possible..... |
The Following User Says Thank You to ravibalani_5 For This Useful Post: |
10-06-2018, 17:29 | #5 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Make sure all pads are making good contact, best is to clean solder. If pads are clean and making contact then you might have a faulty NAND, try a different one. NAND get damaged if you overheat and when pulling out you bend them. |
10-09-2018, 02:44 | #7 (permalink) |
Member: 2691507 Status: Offline Thanks Meter: 100 | Do a "read test" on CE1 and CE2 And just curious, inspect all pins on the socket and make sure they are not bend? What software version are you running? In "ip tools" tab, do a 'Test SN', do you get two SN readings, once for CE1 and once for CE2? 3 different NAND and same result, not sure... are they different brand or same |
The Following 2 Users Say Thank You to cisco2017 For This Useful Post: |
10-19-2018, 12:44 | #8 (permalink) | |
Member: 1315082 Status: Offline Thanks Meter: 16 | Quote:
