02-08-2017, 16:04 | #16 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
i already post many times all ipad 2,3,4 mini,mini2 mini3 mini 4 has fix using this box only changing the sn of course you have a goo skill to do with it because if your not sure to your self then this box can help you to your work | |
02-14-2017, 09:12 | #17 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Quote:
The Following User Says Thank You to juve2106 For This Useful Post: |
02-18-2017, 05:22 | #20 (permalink) | |
Freak Poster Join Date: Nov 2005
Member: 197916 Status: Offline Thanks Meter: 157 | replay Quote:
06-22-2017, 18:13 | #23 (permalink) |
Junior Member Join Date: Aug 2008 Location: phillippines
Member: 836818 Status: Offline Thanks Meter: 24 | its too hard to think that the suppoter didnt have any reply in thus such problem..nand ic is the main problem coz its not supported by the following entry..replace new one from the iphone 4s or buy new from ebay..erase and write the boot,place new serial and fix invalid and back to motherboard then restore...gud luck t.s... |
07-19-2017, 06:47 | #27 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
Not sure if you were able to fix your issue, I noticed the SN on the pics are the default IP BOX SN, is that the number you are using? And not matter what IP Box lovers post here, if your nand is not in the list of supported then IP Box can't help you. There is a reason why they post a list of supported Nand. It will have issues even with supported Nand so maybe you should try a different programmer that supports your Nand or buy one with the SN on it, they work. | |
07-19-2017, 16:25 | #29 (permalink) |
Freak Poster Join Date: Jan 2013 Location: socal
Member: 1866487 Status: Offline Thanks Meter: 113 | Yeah, need to disassemble iPad, remove logic board, remove nand ic, reprogram nand IC, solder back nand ic, reassemble ipad....not an easy job Sent from my SM-G955U using Tapatalk |
The Following User Says Thank You to dam1inc For This Useful Post: |
